Hello, i am desperate with a KNX dimmer actuator. My device is an older Busch-Jaeger UP 6932 U-101 with a 6116 2f-Taster. It is an KNX Powernet device, if it is necessary. It offers the following communication objects:
- switching: GA 1/3/9, Flags K-SÜ–, Type: 1.001
- relative dimming: GA 1/3/10, Flags K-S—, Type 3.007
- dimmer brightness: 1/3/11, Flags KLSÜ–, Type 5.001
- dimmer feedback: 7/3/1, Flags KLSÜ–, Type 1.011
- dimmer preset: 0/1/0, Flags K-SÜ–, Type 1.011
The dimmer device has two “onboard” touch button for using:
- touch button 2 short → switching: 1/3/9
- touch button 2 long → dimming: 1/3/10
Dimming time has a time base of 0.5ms, a faktor of 20 (value between 2..255) and will be calculated over timebase * faktor * 255.
Part of KNX.things:
Thing device bj_up_1_1_5_eg "Busch-Jaeger UP 6932 U-101 (1.1.5)" @ "Wohnzimmer" [ // Busch-Jaeger KNX Powernet UP-Dimmaktor 6932 U-101 & 6116 2f-Taster
address="1.1.5",
fetch=true,
pingInterval=300,
readInterval=3600
Type dimmer : k1 "Wandlampe Wohnzimmer" [ switch="1.001:1/3/9", position="5.001:1/3/11+<1/3/11", increaseDecrease="3.007:1/3/10" ]
Part of knx.items:
Switch s_eg_wohnzimmer_wandlampe "Wandlampe Wohnzimmer" <light> (gWohnzimmer, gLicht, gSchalter) { channel="knx:device:bridge:bj_up_1_1_5_eg:k1"}
Dimmer d_eg_wohnzimmer_wandlampe "Wandlampe Wohnzimmer [%d %%]" <light> (gWohnzimmer, gLicht, gDimmer) { channel="knx:device:bridge:bj_up_1_1_5_eg:k1", autoupdate="false" }
Part of standard.sitemap:
Default item=s_eg_wohnzimmer_wandlampe label="Wandlampen"
Default item=d_eg_wohnzimmer_wandlampe label="Wandlampen"
Many of small things i read in this thread was as a test inside the configuration.
I have the behavior, that after a restart of the openHAB server, the slider in Basic UI and in the iOS App show the right value, when the dimmer is on and e.g. set to 50% brightness. So the read command works. Also switching on and of works, but: when i switch the dimmer with a short touch on the local button on, i can see on the bus monitor (ETS) the following:
1/3/9 GroupValueWrite 1.001 On
1/3/11 GroupValueWrite 5.001 50% (<- example)
7/3/1 GroupValueWrite 1.011 Active
In Basic UI I mostly see the following behavior:
- Switch goes from off to on
- Dimmer jumps from 0 to 100, from 100 to 50 and from 50 to 100 and then stays there.
But the real brightness is 50%. So the slider shows not the right value. When i restart openHAB again, it reads from the bus and show on the slider the correct 50%. I have also a physical KNX display, which knows the correct value. So finally: ![]()
