After many different attempts, I managed to find a way to get into the console. yay =)
This is what the log says when I turn on / off or send brightness-value.
14:40:08.610 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXAktor1Kallare_AK1_Kanal1’ received command ON
14:40:08.617 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXAktor1Kallare_AK1_Kanal1’ predicted to become ON
14:40:08.622 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXAktor1Kallare_AK1_Kanal1’ changed from OFF to ON
14:40:08.642 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘ON’ to datapoint ‘command DP 1/0/1 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:40:08.699 [DEBUG] [x.internal.handler.DeviceThingHandler] - onGroupWrite Thing ‘knx:device:9211b58418’ received a GroupValueWrite telegram from ‘1.1.1’ for destination ‘1/1/1’
14:40:10.700 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXAktor1Kallare_AK1_Kanal1’ received command OFF
14:40:10.707 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXAktor1Kallare_AK1_Kanal1’ predicted to become OFF
14:40:10.712 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXAktor1Kallare_AK1_Kanal1’ changed from ON to OFF
14:40:10.729 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘OFF’ to datapoint ‘command DP 1/0/1 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:40:10.785 [DEBUG] [x.internal.handler.DeviceThingHandler] - onGroupWrite Thing ‘knx:device:9211b58418’ received a GroupValueWrite telegram from ‘1.1.1’ for destination ‘1/1/1’
14:40:13.814 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXAktor1Kallare_AK1Kanal6’ received command ON
14:40:13.819 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXAktor1Kallare_AK1Kanal6’ predicted to become ON
14:40:13.825 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXAktor1Kallare_AK1Kanal6’ changed from OFF to ON
14:40:13.843 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘ON’ to datapoint ‘command DP 1/0/6 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:40:13.900 [DEBUG] [x.internal.handler.DeviceThingHandler] - onGroupWrite Thing ‘knx:device:9211b58418’ received a GroupValueWrite telegram from ‘1.1.1’ for destination ‘1/1/6’
14:40:16.129 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXAktor1Kallare_AK1Kanal6’ received command OFF
14:40:16.132 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXAktor1Kallare_AK1Kanal6’ predicted to become OFF
14:40:16.141 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXAktor1Kallare_AK1Kanal6’ changed from ON to OFF
14:40:16.163 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘OFF’ to datapoint ‘command DP 1/0/6 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:40:16.222 [DEBUG] [x.internal.handler.DeviceThingHandler] - onGroupWrite Thing ‘knx:device:9211b58418’ received a GroupValueWrite telegram from ‘1.1.1’ for destination ‘1/1/6’
14:40:23.605 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command ON
14:40:23.610 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command 100
14:40:23.612 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become ON
14:40:23.618 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become 100
14:40:23.620 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 0 to 100
14:40:23.633 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘ON’ to datapoint ‘command DP 2/0/1 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:40:23.660 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘100’ to datapoint ‘command DP 2/4/1 ‘knx:ip:32127f1551’, DPT id 5.001, low priority’ (0. attempt).
14:40:23.796 [DEBUG] [x.internal.handler.DeviceThingHandler] - onGroupWrite Thing ‘knx:device:32127f1551:d0df9c73ea’ received a GroupValueWrite telegram from ‘1.1.5’ for destination ‘2/1/1’
14:40:28.798 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command OFF
14:40:28.807 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become OFF
14:40:28.813 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 100 to 0
14:40:28.831 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘OFF’ to datapoint ‘command DP 2/0/1 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:40:29.494 [DEBUG] [x.internal.handler.DeviceThingHandler] - onGroupWrite Thing ‘knx:device:32127f1551:d0df9c73ea’ received a GroupValueWrite telegram from ‘1.1.5’ for destination ‘2/3/1’
14:40:29.532 [DEBUG] [x.internal.handler.DeviceThingHandler] - onGroupWrite Thing ‘knx:device:32127f1551:d0df9c73ea’ received a GroupValueWrite telegram from ‘1.1.5’ for destination ‘2/1/1’
14:40:33.731 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command ON
14:40:33.733 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command 42
14:40:33.736 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become ON
14:40:33.739 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become 42
14:40:33.742 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 0 to 100
14:40:33.743 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 100 to 42
14:40:33.757 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘ON’ to datapoint ‘command DP 2/0/1 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:40:33.783 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘42’ to datapoint ‘command DP 2/4/1 ‘knx:ip:32127f1551’, DPT id 5.001, low priority’ (0. attempt).
14:40:33.911 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command ON
14:40:33.913 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command 47
14:40:33.918 [DEBUG] [x.internal.handler.DeviceThingHandler] - onGroupWrite Thing ‘knx:device:32127f1551:d0df9c73ea’ received a GroupValueWrite telegram from ‘1.1.5’ for destination ‘2/1/1’
14:40:33.919 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become ON
14:40:33.923 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become 47
14:40:33.927 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 42 to 100
14:40:33.930 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 100 to 47
14:40:33.932 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 47 to 100
14:40:33.938 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘ON’ to datapoint ‘command DP 2/0/1 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:40:33.966 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘47’ to datapoint ‘command DP 2/4/1 ‘knx:ip:32127f1551’, DPT id 5.001, low priority’ (0. attempt).
14:40:41.512 [DEBUG] [x.internal.handler.DeviceThingHandler] - onGroupWrite Thing ‘knx:device:32127f1551:d0df9c73ea’ received a GroupValueWrite telegram from ‘1.1.5’ for destination ‘2/3/1’
14:40:41.515 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 100 to 47
14:40:41.835 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command ON
14:40:41.846 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command 56
14:40:41.848 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become ON
14:40:41.852 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become 56
14:40:41.856 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 47 to 100
14:40:41.858 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 100 to 56
14:40:41.861 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘ON’ to datapoint ‘command DP 2/0/1 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:40:41.888 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘56’ to datapoint ‘command DP 2/4/1 ‘knx:ip:32127f1551’, DPT id 5.001, low priority’ (0. attempt).
14:40:42.108 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command ON
14:40:42.111 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command 45
14:40:42.114 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become ON
14:40:42.118 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become 45
14:40:42.122 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 56 to 100
14:40:42.124 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 100 to 45
14:40:42.136 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘ON’ to datapoint ‘command DP 2/0/1 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:40:42.162 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘45’ to datapoint ‘command DP 2/4/1 ‘knx:ip:32127f1551’, DPT id 5.001, low priority’ (0. attempt).
14:40:42.839 [DEBUG] [x.internal.handler.DeviceThingHandler] - onGroupWrite Thing ‘knx:device:32127f1551:d0df9c73ea’ received a GroupValueWrite telegram from ‘1.1.5’ for destination ‘2/3/1’
14:41:16.448 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command ON
14:41:16.450 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command 76
14:41:16.453 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become ON
14:41:16.457 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become 76
14:41:16.462 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 45 to 100
14:41:16.464 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 100 to 76
14:41:16.480 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘ON’ to datapoint ‘command DP 2/0/1 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:41:16.508 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘76’ to datapoint ‘command DP 2/4/1 ‘knx:ip:32127f1551’, DPT id 5.001, low priority’ (0. attempt).
14:41:16.709 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command ON
14:41:16.712 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command 83
14:41:16.715 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become ON
14:41:16.719 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become 83
14:41:16.723 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 76 to 100
14:41:16.725 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 100 to 83
14:41:16.736 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘ON’ to datapoint ‘command DP 2/0/1 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:41:16.763 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘83’ to datapoint ‘command DP 2/4/1 ‘knx:ip:32127f1551’, DPT id 5.001, low priority’ (0. attempt).
14:41:20.166 [DEBUG] [x.internal.handler.DeviceThingHandler] - onGroupWrite Thing ‘knx:device:32127f1551:d0df9c73ea’ received a GroupValueWrite telegram from ‘1.1.5’ for destination ‘2/3/1’
14:41:44.340 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command OFF
14:41:44.351 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become OFF
14:41:44.355 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 83 to 0
14:41:44.366 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘OFF’ to datapoint ‘command DP 2/0/1 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:41:45.601 [DEBUG] [x.internal.handler.DeviceThingHandler] - onGroupWrite Thing ‘knx:device:32127f1551:d0df9c73ea’ received a GroupValueWrite telegram from ‘1.1.5’ for destination ‘2/1/1’
14:41:45.643 [DEBUG] [x.internal.handler.DeviceThingHandler] - onGroupWrite Thing ‘knx:device:32127f1551:d0df9c73ea’ received a GroupValueWrite telegram from ‘1.1.5’ for destination ‘2/3/1’
14:41:50.966 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command ON
14:41:50.968 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command 100
14:41:50.970 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become ON
14:41:50.972 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become 100
14:41:50.975 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 0 to 100
14:41:50.994 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘ON’ to datapoint ‘command DP 2/0/1 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:41:51.022 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘100’ to datapoint ‘command DP 2/4/1 ‘knx:ip:32127f1551’, DPT id 5.001, low priority’ (0. attempt).
14:41:51.149 [DEBUG] [x.internal.handler.DeviceThingHandler] - onGroupWrite Thing ‘knx:device:32127f1551:d0df9c73ea’ received a GroupValueWrite telegram from ‘1.1.5’ for destination ‘2/1/1’
14:41:59.326 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command ON
14:41:59.328 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command 69
14:41:59.331 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become ON
14:41:59.333 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become 69
14:41:59.336 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 100 to 69
14:41:59.352 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘ON’ to datapoint ‘command DP 2/0/1 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:41:59.379 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘69’ to datapoint ‘command DP 2/4/1 ‘knx:ip:32127f1551’, DPT id 5.001, low priority’ (0. attempt).
14:41:59.599 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command ON
14:41:59.602 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command 48
14:41:59.607 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become ON
14:41:59.611 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become 48
14:41:59.615 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 69 to 100
14:41:59.616 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 100 to 48
14:41:59.625 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘ON’ to datapoint ‘command DP 2/0/1 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:41:59.651 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘48’ to datapoint ‘command DP 2/4/1 ‘knx:ip:32127f1551’, DPT id 5.001, low priority’ (0. attempt).
14:41:59.771 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command ON
14:41:59.773 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command 47
14:41:59.775 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become ON
14:41:59.781 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become 47
14:41:59.784 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 48 to 100
14:41:59.789 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 100 to 47
14:41:59.800 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘ON’ to datapoint ‘command DP 2/0/1 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:41:59.827 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘47’ to datapoint ‘command DP 2/4/1 ‘knx:ip:32127f1551’, DPT id 5.001, low priority’ (0. attempt).
14:42:00.834 [DEBUG] [x.internal.handler.DeviceThingHandler] - onGroupWrite Thing ‘knx:device:32127f1551:d0df9c73ea’ received a GroupValueWrite telegram from ‘1.1.5’ for destination ‘2/3/1’
14:42:10.264 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command ON
14:42:10.266 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command 73
14:42:10.268 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become ON
14:42:10.270 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become 73
14:42:10.274 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 47 to 100
14:42:10.276 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 100 to 73
14:42:10.290 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘ON’ to datapoint ‘command DP 2/0/1 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:42:10.317 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘73’ to datapoint ‘command DP 2/4/1 ‘knx:ip:32127f1551’, DPT id 5.001, low priority’ (0. attempt).
14:42:10.466 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command ON
14:42:10.469 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command 77
14:42:10.471 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become ON
14:42:10.475 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become 77
14:42:10.478 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 73 to 100
14:42:10.480 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 100 to 77
14:42:10.492 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘ON’ to datapoint ‘command DP 2/0/1 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:42:10.519 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘77’ to datapoint ‘command DP 2/4/1 ‘knx:ip:32127f1551’, DPT id 5.001, low priority’ (0. attempt).
14:42:13.347 [DEBUG] [x.internal.handler.DeviceThingHandler] - onGroupWrite Thing ‘knx:device:32127f1551:d0df9c73ea’ received a GroupValueWrite telegram from ‘1.1.5’ for destination ‘2/3/1’
14:42:15.857 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command ON
14:42:15.859 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command 46
14:42:15.861 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become ON
14:42:15.866 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become 46
14:42:15.869 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 77 to 100
14:42:15.871 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 100 to 46
14:42:15.885 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘ON’ to datapoint ‘command DP 2/0/1 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:42:15.912 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘46’ to datapoint ‘command DP 2/4/1 ‘knx:ip:32127f1551’, DPT id 5.001, low priority’ (0. attempt).
14:42:16.126 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command ON
14:42:16.133 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command 32
14:42:16.136 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become ON
14:42:16.139 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become 32
14:42:16.143 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 46 to 100
14:42:16.145 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 100 to 32
14:42:16.153 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘ON’ to datapoint ‘command DP 2/0/1 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:42:16.179 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘32’ to datapoint ‘command DP 2/4/1 ‘knx:ip:32127f1551’, DPT id 5.001, low priority’ (0. attempt).
14:42:16.320 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command ON
14:42:16.322 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ received command 30
14:42:16.324 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become ON
14:42:16.326 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item ‘KNXDimmer1Kok_Kanal1’ predicted to become 30
14:42:16.329 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 32 to 100
14:42:16.331 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘KNXDimmer1Kok_Kanal1’ changed from 100 to 30
14:42:16.349 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘ON’ to datapoint ‘command DP 2/0/1 ‘knx:ip:32127f1551’, DPT id 1.001, low priority’ (0. attempt).
14:42:16.376 [DEBUG] [knx.internal.client.AbstractKNXClient] - Wrote value ‘30’ to datapoint ‘command DP 2/4/1 ‘knx:ip:32127f1551’, DPT id 5.001, low priority’ (0. attempt).
14:42:21.344 [DEBUG] [x.internal.handler.DeviceThingHandler] - onGroupWrite Thing ‘knx:device:32127f1551:d0df9c73ea’ received a GroupValueWrite telegram from ‘1.1.5’ for destination ‘2/3/1’
