yes, i have physical contact sensor (based on homematic) that reports open/close state for the door
I am a little confused on the DPT for my contact sensor.
In the documentation they write Default DPT for a contact is 1.009
But in the attached example near the end of the page they use 1.019 as DPT.
Type contact : demoContact "Door" [ ga="1.019:<5/1/2" ]
What is right now and what do I use if I have more contacts (like window contacts)?
Also State is not read from contact. Is your physical contact thing also from type contact?
I am also getting warnings in the log file after restarting openhab:
2020-08-09 19:31:36.449 [WARN ] [essories.HomekitGarageDoorOpenerImpl] - Current door state not available. Relaying value of CLOSED to HomeKit
2020-08-09 19:31:36.450 [WARN ] [essories.HomekitGarageDoorOpenerImpl] - Unsupported value NULL for garageTargetState. Only CLOSED and OPEN supported. Check HomeKit settings if you want to change the mapping
If found out now that using “String” does not work for me.
String garageDoorStatus "Garage door Status [%s]" <door> (gGarageDoor) {homekit="ContactSensor",.......}
I have to use a Contact
Contact garageDoorStatus "Garagentor [%s]" <door> (KG_Garage) {homekit="ContactSensor",.......}
So now after a while restarting contact sensor for the door is read correct using
knx.things
Type contact : garagentorSensor "Garangentor Status" [ga="1.019:<2/0/1"]
knx.items
Contact garageDoorStatus "Garagentor [%s]" <door> (KG_Garage) {homekit="ContactSensor", channel="knx:device:bridge:Garagentor_Sensor:garagentorSensor" }
The syntax on the rules file is so bad. I am trying this rule:
rule "garage door state update"
Item garageDoorStatus received update
logDebug("GarageDoor", "garageDoorStatus.state --> " + garageDoorStatus.state )
var curState = garageDoorStatus.state
logDebug("GarageDoor", "curState --> " + curState )
switch(curState) {
case "OPEN": {
logDebug("GarageDoor", "case OPEN done" )
garageCurrentState.sendCommand("OPEN")
garageTargetState.postUpdate("OPEN")
case "CLOSED": {
logDebug("GarageDoor", "case CLOSED done" )
garageCurrentState.sendCommand("CLOSED")
garageTargetState.postUpdate("CLOSED")
But the switch statement is not working and I don’t know why.
Log is outputting everything until switch(curState)…
Oh really?! It must case the command and not the string of the command.
switch(curState) {
case OPEN: {
case CLOSED: {
So now it works with this rules. I think it is totally confusing. Receiving an update is posted as Command (no string e.g OPEN) but receiving a command is posted as string (e.g “OPEN”)
Here is the solution for using an UP and DOWN button for a garageDoorOpener with KNX:
knx.things
/*Garagentor*/
Thing device Schaltaktor_Garagentor [
address="1.1.6",
fetch=true,
pingInterval=300,
readInterval=3600
Type switch : garagentorAuf "Garagentor Auf" [ga="2/0/2"]
Type switch : garagentorZu "Garagentor Zu" [ga="2/0/3"]
Thing device Garagentor_Sensor [
address="1.1.15",
fetch=true,
pingInterval=300,
readInterval=3600
knx.items
Group gGarage "Garage HomeKit" {homekit="GarageDoorOpener"}
/*Garage*/
Switch garagentorAuf "Garagentor Auf" (KG_Garage) { channel="knx:device:bridge:Schaltaktor_Garagentor:garagentorAuf" }
Switch garagentorZu "Garagentor Zu" (KG_Garage) { channel="knx:device:bridge:Schaltaktor_Garagentor:garagentorZu" }
knx.rules (logDebug can be ignored)
switch(curState) {
case OPEN: {
garageTargetState.sendCommand("OPEN")
case CLOSED: {
garageTargetState.sendCommand("CLOSED")
rule "garage door target state"
Item garageTargetState received command
logDebug("GarageDoor", "garageTargetState.state --> " + garageTargetState.state )
var curTargetState = garageTargetState.state
logDebug("GarageDoor", "curTargetState --> " + curTargetState )
switch(curTargetState) {
case "OPEN": {
logDebug("GarageDoor", "Garage Door will be open")
garagentorAuf.sendCommand(ON)
//garagentorAuf.postUpdate(OFF)
case "CLOSED": {
logDebug("GarageDoor", "Garage Door will be closed")
garagentorZu.sendCommand(ON)
//garagentorZu.postUpdate(OFF)
Only one thing is still to solve: What if the door is opening or closing and you change the state in den garageOpener item in homekit. In my case the door stops in current position. I think another rule is needed. Maybe also a second physical contact too.
cool. you found the solution.
im also thinking about the second contact sensor. currently i can only see whether the garage is closed or not, but not whether it is completely open or stopped somewhere in the middle… maybe even something with movement sensor…
I will think about it next days. I have an unused channel on my knx device. Maybe i will get another physical magnetic contact and test it then.
Thank you very much eugen for your help and your sample code!
An idea could be to run a timer on open or closing the garage door. If a „stop command“‘is send, then the timer is stoppt and you know, that the door is neither open nor closed if timer is not run to zero. And before starting the timer store the current state of the door into a variable.
Could be getting complex, but maybe will work.
