Hello.
Does anybody know how to configure a thing to get the garage door opener icon on Apple CarPlay?
Hello.
Hi Georg,
not sure at which stage you are. Do you have garage door opener already connected via KNX with openHAB? Do you have Garage Door Opener accessory already in your home app on your iphone/ipad?
Hey eugen.
I had one switch for open and close the grage door in openhab and HomeKit, so far. Now i changed the knx wiring to have a switch for open and another for close. I have not setup this two switches in openhab. I will do this in the next few weeks. When i have an open and an close switch in openhab then i have to think about how to map them to HomeKit. The question is how to map them to HomeKit to see a garage door opener in the HomeKit App and the garage door icon in car play. I have to figure out, how to configure the HomeKit item in openhab, so that the HomeKit show it as a garage door opener and carPlay shows the button. I even donât know if this is possible.
Hi Georg,
sure, it is possible.
the solution with one switch would be easier than with 2 switches but it is possible with 2 as well. questions
Hey Eugen,
i changed from one to two switches, because of having up and diwn directions. So if i am ready i can tell siri to open the garage door or close the garage door.
I am doing everything by text file. I am still running a couple of items and have them allready in HomeKit (e.g Rollershutters, Switches, window sensors).
Hi Eugen,
i am sitting now infront of my openhab configuration.
As I said I have two knx adresses: one for garage door up (2/0/2) and one for down (2/0/3)
if have added the following to my knx.things configuration:
/*Garagentor*/
Thing device Schaltaktor_Garagentor [
address="1.1.6",
fetch=true,
pingInterval=300,
readInterval=3600
Type switch : garagentorAuf "Garagentor Auf" [ga="2/0/2"]
Type switch : garagentorZu "Garagentor Zu" [ga="2/0/3"]
And to my knx.items file I added this:
Switch garagentorAuf "Garagentor Auf" <garagedoor> (KG_Garage) ["Switchable"] { channel="knx:device:bridge:Schaltaktor_Garagentor:garagentorAuf", autoupdate="false" }
Switch garagentorZu "Garagentor Zu" <garagedoor> (KG_Garage) ["Switchable"] { channel="knx:device:bridge:Schaltaktor_Garagentor:garagentorZu", autoupdate="false" }
How can I set this up to get the Garage Door Opener for CarPlay?
It is bad, that there is no example in the documentation for the garage door opener.
Hi Georg,
you are right. the example is missing in the documentation.
here is my configuration of garage opener
Group gGarage "Garage" {homekit="GarageDoorOpener"}
Switch garageObstruction "Garage Obstruction" (gGarage) {homekit="ObstructionStatus"}
String garageCurrentState "Garage Current State [%s]" (gGarage) {homekit="CurrentDoorState"}
String garageTargetState "Garage Target State [%s]" (gGarage) {homekit="TargetDoorState", alexa="ModeController.mode" [category="EXTERIOR_BLIND", supportedModes="Closed=@Value.Close, Open=@Value.Open",actionMappings="Close=Closed,Open=Open", friendlyNames="Garage", language="de"]}
the items above are all virtual items. then i have two items that is mapped to homematic garage opener device and to open/close sensor.
String garageDoorStatus "Garage doorr Status [%s]" <door> (gGarageDoor) {homekit="ContactSensor", channel="homematic:HMIP-SWDO:rasmatic:0000DA498D0C1D:1#STATE"}
Switch garageSwitch "Garage door" {channel="homematic:HmIP-WGC:rasmatic:00131709AE33F4:3#STATE"}
and the rules which maps the real devices to virtual items
rule "garage door state update"
Item garageDoorStatus received update
if (garageDoorStatus.state == "OPEN" ) {
garageCurrentState.sendCommand("OPEN")
garageTargetState.postUpdate("OPEN")
} else {
garageCurrentState.sendCommand("CLOSED")
garageTargetState.postUpdate("CLOSED")
garageSwitch.sendCommand(OFF)
rule "garage door target state"
Item garageTargetState received command
garageSwitch.sendCommand(ON)
maybe rules can be optimised but they are working for me.
and once it is defined as homekit garage opener accessory it will also appear in carplay.
Thank you eugen for your code. As I see (and you also wrote) you have one switch but I have now Up and Down. The behaviour is like this: If you press UP the door opens and if you press any switch again the door stops.
I will try to implement your code but I am not sure doing this for UP/DOWN-Switches.
The Alexa stuff can be deleted, can it?
Oh you have language=âdeâ. Are you speaking German? I am from Austria.
i have only one switch for garage opener which react on event like this âOpen-Stop-Close-Stopâ
alexa stuff can be removed.
do you have a sensor or other way to derive the current status of the door, e.g. close/open?
at the end you need to provide the current and target states.
e.g. if âUPâ switch is activated you would set the target state to âOPENâ, if âDOWNâ is activated then to âCLOSEDâ.
I have now implemented this in my items file but the garagedooropener is not shown in my HomeKit app.
String garageTargetState "Garage Target State [%s]" (gGarage) {homekit="TargetDoorState"}
hm. if you just added these lines you should already see garage door in home app. if it does not appear:
I did a restart already and also reset the HomeKit bindings (sin openhab console)
I have Homekit 2.5.3 integration, I think this is an actual one.
ok. 2.5.3 is a pretty old one. the latest one is 2.5.7
check this post for update instructions
Can u tell me, what I have to provide for âid of homekit bindingâ in the update command?
Edit Ok I got it by using âlistâ command
Ok, now I see the garage door opener in the homekit app. I have to check now if my modified rule is working.
It seems I have a logic issue in my rules.
garagentorZu.postUpdate(OFF)
garagentorAuf.postUpdate(OFF)
} else {
if (garageTargetState.state == "OPEN") {
garagentorAuf.sendCommand(ON)
} else if (garageTargetState.state == "CLOSED") {
garagentorZu.sendCommand(ON)
lets first focus on garageTargetState rule. this rule gets triggered when you change garage door target state in home app, e.g. click on âclose doorâ
important is to know the difference between sendCommand and postUpdate.
means, in your case you should use sendCommand for garagentorAuf/garagentorZu.
e.g.
garagentorZu.sendCommand(OFF)
the next is to check whether garagentorAuf/garagentorZu are working independent of homekit. what happens if you change the values via paper UI?
I am not at home now. When i am back i am going to check the rules again.
I guess i have to rethink my rules. Also i am using a real contact sensor for the state of the door. This i a knx contact which sends contact close when door is completely closed and open when door is not in closed state.
Do you also have a real contact on your door?
garagentorAuf / garagentorZu Items are working. I have them visible in Homekit and Openhab Ui.
In garageTargetState rule i am sending the command to the items. The postUpdate command is to set the visible state in the Ui (Homekit ui and openhab ui).
This is because openhab does not have push buttons.
