Hi Everybody
The Basic functionality (switches) with openhab works fine and I’m impressed by the simplicity of the configuration (until now :slight_smile). I’m using the 1.8.1 (and checked the change log for 1.8.2 about DataPointType issues etc.).
I’m trying to display values from the KNX Bus in Opemhab.
To verify the displayed values, I have a ProServ running in parallel (and of course the ETS5 Monitors).
I tried to get proper results with different DataPointTypes without luck This implies i have missed something fundamental.
Here the sample:
ETS5 Monitor:
RawData «29 00 BC E0 11 46 01 F3 05 00 40 3E 9C D1 75»
DataPointType «14.019»
DecodedDpValue «3E 9C D1 75 | 0.3062855»
RawDpValue «3E 9C D1 75»
Correct display on ProServ:
«0.3062855 A»
BUT
Incorrect display on Openhab:
«2165.7600 A»
Here the extract of «default.items» regarding the 0/1/243:
Number Bus_A “KNX Bus [%f A]” (Energie) {knx = “<0/1/243”}
As this is a rainy Sunday, does is anybody has a hint, what i have to check, change or add
Please tell me if i have to post additional files (or extracts).
A generic procedure will also be fine for me (and all other beginners)…
Thank you so much for all the support…
KR
