- Platform information:
- Hardware: BeagleBone Black 512MB RAM
- OS: Debian Linux 10.0
- Java Runtime Environment: java version “1.8.0_181”
- openHAB version: 2.4.0-1
- Issue of the topic: KXN Device stays offline, error in logs
- Please post configurations (if applicable):
- Items configuration: not yet created
- Sitemap configuration: not yet created
- Rules code: not yet created
- Services configuration: not yet created
- If logs where generated please post these here using code fences:
I am quite new to OpenHAB, but not to linux. So, I installed OpenHAB via apt (on my BeagleBone) and started it. I followed the New User Tutorial with the Network Binding and then tried to add a KNX Binding. This worked also well - my Controller (the same computer) is online and visible.
But then I tried to add a KNX Device, an actor-controller. I filled all the configuration details, but device stays offline.
in the log I find this:
2019-09-10 14:27:48.507 [ERROR] [ome.core.thing.link.ThingLinkManager] - Exception occurred while informing handler: null java.lang.NullPointerException: null
at java.util.Objects.requireNonNull(Objects.java:203) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.getChannelTypeUID(DeviceThingHandler.java:252) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.isControl(DeviceThingHandler.java:246) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.channelLinked(DeviceThingHandler.java:138) ~[?:?]
at org.eclipse.smarthome.core.thing.link.ThingLinkManager.lambda$0(ThingLinkManager.java:300) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
what am I missing here?
