I am kind of lost now with this problem:
If I want to control some group addresses, an error within openhab is thrown (see log below) and no command is sent to the devices. When I use the ets5 group monitor to issue the command, the rollershutter and switches act as programmed. Of the 200 group addresses, only 7 show this behavior.
In my things definition, I can only reach my mdt ip router device using the TUNNEL mode. I have not found a working config to use it in ROUTER mode:
Bridge knx:ip:bridge [
ipAddress=“192.168.0.55”,
portNumber=3671,
localIp=“192.168.0.62”,
type=“TUNNEL”,
readingPause=50,
responseTimeout=10,
readRetriesLimit=10,
autoReconnectPeriod=1,
localSourceAddr=“0.0.0”,
numberOfThreads=4
2018-07-14 22:43:31.500 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception
java.lang.IllegalArgumentException: tuwien.auto.calimero.KNXFormatException: invalid group address: 0/0/314
at org.openhab.binding.knx.internal.channel.AbstractSpec.toGroupAddress(AbstractSpec.java:50) ~[?:?]
at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:193) ~[?:?]
at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1382) ~[?:?]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481) ~[?:?]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471) ~[?:?]
at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:708) ~[?:?]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:?]
at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:499) ~[?:?]
at org.openhab.binding.knx.internal.channel.ListenSpecImpl.(ListenSpecImpl.java:35) ~[?:?]
at org.openhab.binding.knx.internal.channel.KNXChannelType.lambda$2(KNXChannelType.java:186) ~[?:?]
at java.util.HashMap$KeySpliterator.tryAdvance(HashMap.java:1574) ~[?:?]
at java.util.stream.ReferencePipeline.forEachWithCancel(ReferencePipeline.java:126) ~[?:?]
at java.util.stream.AbstractPipeline.copyIntoWithCancel(AbstractPipeline.java:498) ~[?:?]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:485) ~[?:?]
at java.util.stream.FindOps$FindOp.evaluateSequential(FindOps.java:152) ~[?:?]
at java.util.stream.ReferencePipeline.findFirst(ReferencePipeline.java:464) ~[?:?]
at org.openhab.binding.knx.internal.channel.KNXChannelType.getListenSpec(KNXChannelType.java:188) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.lambda$8(DeviceThingHandler.java:270) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.withKNXType(DeviceThingHandler.java:121) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.onGroupWrite(DeviceThingHandler.java:269) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.onGroupReadResponse(DeviceThingHandler.java:259) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient$1.lambda$2(AbstractKNXClient.java:121) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.lambda$8(AbstractKNXClient.java:254) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Caused by: tuwien.auto.calimero.KNXFormatException: invalid group address: 0/0/314
at tuwien.auto.calimero.GroupAddress.init(GroupAddress.java:301) ~[?:?]
at tuwien.auto.calimero.GroupAddress.(GroupAddress.java:128) ~[?:?]
at org.openhab.binding.knx.internal.channel.AbstractSpec.toGroupAddress(AbstractSpec.java:48) ~[?:?]
… 32 more
Caused by: tuwien.auto.calimero.KNXIllegalArgumentException: address group out of range
at tuwien.auto.calimero.GroupAddress.init(GroupAddress.java:308) ~[?:?]
at tuwien.auto.calimero.GroupAddress.init(GroupAddress.java:297) ~[?:?]
