My knx binding works excellent, able to control all lights.
I have a knx switch configured in the house which turns all lights off, using GA 8/0/2
I now want an action to also turn off all music devices (denon speakers) in the house when I press this physical knx button.
I’ve done this with a rule as following:
rule "Turn off music when leaving the house"
Item Licht_alles_uit received command OFF
Denon_power.sendCommand(OFF)
The problem is that the item “Licht_alles_uit” does not receive any OFF command (when checking the log).
The item is configured as following:
in knx.things:
Thing device DUMMY "Dummy" @ "KNX"
Type switch : Channel_0 "" [ ga="1.001:8/0/2+<8/0/2"] // All lights + audio off
and in knx.items:
Switch Licht_alles_uit "alles uit" <switch-off> (gLightAll) ["Switch"] {channel="knx:device:BAOS771:DUMMY:Channel_0"}
When I switch the item in openhab itself (through a sitemap button), the rule works flawlessly. All lights go off, the rule fires and the music turns off.
However when I physically press my knx button in the house, only the lights go off (as configured in ETS), but the rule does not fire. Through the bus monitor in ETS I can see that 8/0/2 is indeed sent to te bus.
I can see the root cause in frontail
- There is no event “Licht_alles_uit received command OFF” registered when I press the physical knx button.
- In contrast, this event is of course recorded when I switch the item from openhab itself.
How can I resolve this? My assumption was that the +<8/0/2 configuration would read the 8/0/2 GA from the knx bus when the physical switch is pressed, but apparently this is not te case.
Thanks for the support
