Knx: negative confirmation of
My setup:
  • Windows 10
  • openjdk version “17.0.10” 2024-01-16 LTS
  • OpenJDK Runtime Environment Zulu17.48+15-CA (build 17.0.10+7-LTS)
  • OpenJDK 64-Bit Server VM Zulu17.48+15-CA (build 17.0.10+7-LTS, mixed mode, sharing)
  • openHAB 4.2.0, Build #4122
Dear all
after many years being on OH 2.x I recently switched to OH 4.2.0.
Basically everything works fine - guys, you are doing a great job…really impressive - thanks for alle the effort that you spent here.
One thing remains (more confusing than really being a problem): in my log files I see continuously these entries:
2024-07-13 09:51:00.374 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.33: 2e 00 91 60 10 ff 11 21 00 81
2024-07-13 09:51:00.413 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.33: 2e 00 91 60 10 ff 11 21 00 81
2024-07-13 09:51:00.455 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.33: 2e 00 91 60 10 ff 11 21 00 81
2024-07-13 09:51:00.491 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.33: 2e 00 91 60 10 ff 11 21 00 81
2024-07-13 09:51:05.605 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.36: 2e 00 91 60 10 ff 11 24 00 81
2024-07-13 09:51:05.623 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.36: 2e 00 91 60 10 ff 11 24 00 81
2024-07-13 09:51:05.663 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.36: 2e 00 91 60 10 ff 11 24 00 81
2024-07-13 09:51:05.705 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.1: 2e 00 9d 60 10 ff 11 01 01 43 00
2024-07-13 09:51:05.740 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.36: 2e 00 91 60 10 ff 11 24 00 81
2024-07-13 09:51:05.780 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.1: 2e 00 91 60 10 ff 11 01 00 81
2024-07-13 09:51:05.945 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.1: 2e 00 91 60 10 ff 11 01 00 81
2024-07-13 09:51:06.064 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.1: 2e 00 91 60 10 ff 11 01 00 81
2024-07-13 09:51:06.082 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.1: 2e 00 91 60 10 ff 11 01 00 81
2024-07-13 09:51:06.208 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.62: 2e 00 91 60 10 ff 11 3e 00 81
2024-07-13 09:51:06.247 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.62: 2e 00 91 60 10 ff 11 3e 00 81
2024-07-13 09:51:06.307 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.62: 2e 00 91 60 10 ff 11 3e 00 81
2024-07-13 09:51:11.467 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.21: 2e 00 91 60 10 ff 11 15 00 c2
2024-07-13 09:51:11.527 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.21: 2e 00 91 60 10 ff 11 15 00 81
2024-07-13 09:51:11.545 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.21: 2e 00 91 60 10 ff 11 15 00 81
2024-07-13 09:51:11.584 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.21: 2e 00 91 60 10 ff 11 15 00 81
2024-07-13 09:51:11.665 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.17: 2e 00 91 60 10 ff 11 11 00 81
2024-07-13 09:51:11.707 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.17: 2e 00 91 60 10 ff 11 11 00 c2
2024-07-13 09:51:11.746 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.17: 2e 00 91 60 10 ff 11 11 00 81
2024-07-13 09:51:11.764 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.37: 2e 00 91 60 10 ff 11 25 00 80
2024-07-13 09:51:11.922 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.37: 2e 00 91 60 10 ff 11 25 00 81
2024-07-13 09:51:12.001 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.37: 2e 00 91 60 10 ff 11 25 00 81
2024-07-13 09:51:12.022 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.37: 2e 00 91 60 10 ff 11 25 00 81
2024-07-13 09:51:12.061 [WARN ] [calimero.link.192.168.0.253:3671    ] - negative confirmation of 1.1.37: 2e 00 91 60 10 ff 11 25 00 81
After checking the forum, the best advise I could find was “just wait, this will disappear”. Well, I’m waiting for several weeks but as you can see my log still gets spammed with these entries. I guess there is still an invalid configuration and would like to ask you for all for advise how/where to investigate. If required I can provide more information about my configuration but currently don’t know what is required.
Thanks & best regards
John
Most likely you have setup some GA (Group Address) to be read which can’t.
Please check every GA configuration for the < sign. This is only allowed for GA where exactly one CO (Communication Object) is set to be readable (R-Flag set, GA is first GA configured for the CO)
