Hi
That’s extremely helpful,
This is my KNX.thing file so far:
Bridge knx:ip:INSIDECONTROL “Knx Inside Control Ip Gateway”[
type=“TUNNEL”,
ipAddress=“192.168.1.25”,
portNumber=3671,
localIp=“0.0.0.0”,
readingPause=50,
responseTimeout=10,
readRetriesLimit=3,
autoReconnectPeriod=30,
localSourceAddr=“0.0.0” ]
Thing device SW2 “Knx Switch SW2 First Floor” [ address=“1.1.17”, fetch=true, pingInterval=600, readInterval=0 ]
Type switch : Channel_21 “Channel 2.1” [ ga=“0/1/15+<1/1/18” ]
Thing device D3 “Knx Dimmer D6 First Floor” [address=“1.1.32”, fetch=true, pingInterval=600,readInterval=0 ]
Type dimmer: Channel_22 “First Floor Bath Lights” [switch=“0/1/12”,position=“0/1/14”,increaseDecrease=“0/1/13”]
Thing device D4 “KNX Dimmer D4 First Floor” [address=“1.1.34”, fetch=true, pingInterval=600,readInterval=0 ]
Type dimmer: Channel_23 “Middle Bed Main Lights” [switch=“0/1/0”,position=“0/1/2”,increaseDecrease=“0/1/1”]
Type dimmer: Channel_24 “Channel 2.4” [switch=“0/1/3”,position=“0/1/5”,increaseDecrease=“0/1/4”]
Thing device D5 “Knx Dimmer D5 First Floor” [address=“1.1.35”, fetch=true, pingInterval=600,readInterval=0 ]
Type dimmer: Channel_25 “Channel 2.5” [switch=“0/1/6”,position=“0/1/8”,increaseDecrease=“0/1/7”]
Type dimmer: Channel_26 “Channel 2.6” [switch=“0/1/9”,position=“0/1/11”,increaseDecrease=“0/1/10”]
Thing device SW3 “Knx Switch SW3 Second Floor” [address=“1.1.16”, fetch=true, pingInterval=600,readInterval=0 ]
Type switch: Channel_31 “Basin Lights Ensuite Bath” [ga=“0/2/0”]
Type switch: Channel_32 “Second Floor Stair Lights” [ga=“0/2/16”]
Thing device D7 “Knx Dimmer D7 Second Floor” [address=“1.1.37”, fetch=true, pingInterval=600,readInterval=0 ]
Type dimmer: Channel_33 “Ensuite Bath Lights” [switch=“0/2/1”,position=“0/2/3”,increaseDecrease=“0/2/2”]
Type dimmer: Channel_34 “Mast Bed Main Lights” [switch=“0/2/4”,position=“0/2/6”,increaseDecrease=“0/2/5”]
Thing device D8 “Knx Dimmer D8 Second Floor” [address=“1.1.36”, fetch=true, pingInterval=600,readInterval=0 ]
Type dimmer: Channel_35 “Mast Bed Bed Light RH” [switch=“0/2/7”,position=“0/2/9”,increaseDecrease=“0/2/8”]
Type dimmer: Channel_36 “Mast Bed Bed Light LH” [switch=“0/2/10”,position=“0/2/12”,increaseDecrease=“0/2/11”]
Thing device D9 “Knx Dimmer D9 Second Floor” [address=“1.1.35”, fetch=true, pingInterval=600,readInterval=0 ]
Type dimmer: Channel_37 “Mast Bed Bed Light 1” [switch=“0/2/13”,position=“0/2/15”,increaseDecrease=“0/2/14”]
Type dimmer: Channel_38 “Mast Bed Bed Light 2” [switch=“0/2/26”,position=“0/2/30”,increaseDecrease=“0/2/27”]
Thing device SW4 “Knx Switch SW4 Third Floor” [address=“1.1.12”, fetch=true, pingInterval=600,readInterval=0 ]
Type switch: Channel_41 “Kitchen Cabinet Lights”[ga=“0/3/9”]
Type switch: Channel_42 “Kitchen Toilet Lights” [ga=“0/3/10”]
Type switch: Channel_43 “Kitchen Lobby Lights” [ga=“0/3/111”]
Type switch: Channel_44 “Roof Terrace Lights” [ga=“0/6/3”]
Thing device D10 “Knx Dimmer D10 Third Floor” [address=“1.2.10”, fetch=true, pingInterval=600,readInterval=0 ]
Type dimmer: Channel_45 “Kitchen Centre Lights”[switch=“0/3/0”,position=“0/3/2”,increaseDecrease=“0/3/1”]
Type dimmer: Channel_46 “Kitchen Door Lights” [switch=“0/3/3”,position=“0/3/5”,increaseDecrease=“0/3/4”]
Thing device D11 “Knx Dimmer D11 Third Floor” [address=“1.2.9”, fetch=true, pingInterval=600,readInterval=0 ]
Type dimmer: Channel_47 “Kitchen Window Lights”[switch=“0/3/6”,position=“0/3/8”,increaseDecrease=“0/3/7”]
Type dimmer: Channel_48 “Third Floor Stair Lights” [switch=“0/3/3”,position=“0/3/5”,increaseDecrease=“0/3/4”]
Thing device D12 “Knx Dimmer D12 Third Floor” [address=“1.2.6”, fetch=true, pingInterval=600,readInterval=0 ]
Type dimmer: Channel_49 “Lounge Wall Lights 1”[switch=“0/4/0”,position=“0/4/2”,increaseDecrease=“0/4/1”]
Thing device D13 “Knx Dimmer D13 Third Floor” [address=“1.2.5”, fetch=true, pingInterval=600,readInterval=0 ]
Type dimmer: Channel_50 “Lounge Wall Lights 2”[switch=“0/4/6”,position=“0/4/8”,increaseDecrease=“0/4/7”]
Type dimmer: Channel_51 “Lounge Wall Lights 3”[switch=“0/4/9”,position=“0/4/11”,increaseDecrease=“04/11”]
Thing device D14 “Knx Dimmer D14 Third Floor” [address=“1.2.4”,fetch=true, pingInterval=600,readInterval=0 ]
Type dimmer: Channel_52 “Lounge 5A Lights 1” [switch=“0/4/12”,position=“0/4/14”,increaseDecrease=“0/4/13”]
Type dimmer: Channel_53 “Lounge 5A Lights 2” [switch=“0/4/15”,position=“0/4/17”,increaseDecrease=“0/4/16”]
I have named and listed each actuator, with its PA, and then added channels?
