sorry but I have no idea how to start with it. I thought it was easily made with some additional meta data..
I have a Ikea blind, that is linked to openhab via deconz binding. Working so far: I can control it via openhab.
Now, I want to control it with a KNX wallswitch. I have created a ‘virtual’ channel in my KNX things for that with the type of rollershutter-control.
But my question is how to link this to rollershutter items, that the KNX follows the deconz item?
(running OH3)
A knx *-control channel is to control a non knx device with knx hardware (e.g. a knx wall switch to control the ikea blinds).
The technical difference between a control and a non control channel is:
knx channel incomming outgoing
control command postUpdate
non control status sendCommand
So, for a control channel an incoming message will result in a trigger “received command”. For a non control channel an incoming message will result in a “received update” (and maybe a “changed” event).
If you want to use it that way, simply link both knx-control channel and deconz channel to the same rollershutter Item.
