cola
(Ursin Cola)
April 22, 2022, 6:00am
#1
Hi all
I have setup a opehnab3.3 and try now to bind my knx system. All our Rollershutters have also angle control. The widget of openhab only can handle up down and stop. So I try (how I read here) to use a “dimmer”, because the angle control must send a 5.001. I try with another system and they was sended it as 5.001 command.
My knx.things looks like bellow
Type rollershutter : rollOGWohnzimmer "Rolladen Wohnzimmer (OG)" [ upDown="2/4/196", stopMove="2/4/198", position="2/4/201+<24/4/177" ]
Type dimmer : rollOGWohnzimmerAngle "Rolladen Wohnzimmer (OG), Angle" [ ga="2/4/200+<24/4/179" ]
My knx.items looks like bellow
Rollershutter RollOGWohnzimmer "Rolladen wohnzimmer (og) [%d %%]" {channel="knx:device:bridge:generic:rollOGWohnzimmer"}
Dimmer RollOGWohnzimmerAngle "Rolladen wohnzimmer (og), angle [%d %%]" {channel="knx:device:bridge:generic:rollOGWohnzimmerAngle"}
I was watching into my busmonitor (ETS), but I never see the the command they was sended for the “Dimmer”…
Any ideas how to solve this?
dimmer parameter is called position, not ga
Type dimmer : rollOGWohnzimmerAngle "Rolladen Wohnzimmer (OG), Angle" [ position="2/4/200+<24/4/179" ]
Jonas88
(Jonas)
April 22, 2022, 8:53am
#3
Here’s my code in case you want to take a look at it:
Type rollershutter : EG_Treppenhaus_Jalousie_Fenster_Position [ upDown="3/1/0", stopMove="3/2/0", position="3/3/0+<3/5/0" ]
Type dimmer : EG_Treppenhaus_Jalousie_Fenster_Winkel [ increaseDecrease="3/2/0", position="5.001:3/4/0+<3/6/0" ]
cola
(Ursin Cola)
April 22, 2022, 10:11am
#4
Thank you so much! I will try it. Can you give me a hint how to send i.e. the angle to 20% over a ECMAScript?
I don’t use ECMA, but it’s a simple sendCommand, nothing special.
As Blocky creates ECMA code, you could build a simple rule in Blockly and read the generated code.
cola
(Ursin Cola)
April 26, 2022, 4:36am
#6
@Jonas88 Thank you for your Example, can you explain me the parameter increaseDecrease? In my case, which GA did I need for it?
cola
(Ursin Cola)
April 26, 2022, 4:37am
#7
@Udo_Hartmann thank you! this is working!
increaseDecrease is DPT3.007, INCREASE/DECREASE. If using absolute positioning, you won’t need this parameter. In fact, I’m using it only to control things from knx via dimmer wall switch (which is only able to send ON/OFF (short press) or INCREASE/DECREASE (long press)
