KNX router is online, but all things are offline
I’ve created a KNX router with network address 224.0.23.12 and used it as a bridge for my other KNX things. This worked in December, but when I switched to version 4.3.2 this is no longer working.
The KNX router is online, but all things that are using this router are offline.
Do you know what I’m doing wrong?
Ivan
Hi there:
I’m desperate. Do you know what could be wrong? This is my configuration.
UID: knx:ip:00c5-0106ac4b
label: R20A KNX IP Router (router mode)2
thingTypeUID: knx:ip
configuration:
  useNAT: false
  readRetriesLimit: 3
  ipAddress: 224.0.23.12
  autoReconnectPeriod: 60
  localIp: 172.16.30.11
  localSourceAddr: 0.0.0
  readingPause: 50
  type: ROUTER
  portNumber: 3671
  responseTimeout: 10
Thanks a million.
Ivan
I switched from router mode to tunnel mode to see if the problem was within our network, as router mode was producing ambiguous results. This helped me get predictable results KNX connection.Steps I took to fix it:
  1. I deleted the existing KNX router from my Things.
  2. I added a new bridge by clicking the plus sign on the Things page and scanning for devices.
  3. I selected “Tunnel” instead of “Router” during setup and saved the configuration.
  4. I checked my KNX devices, and they came online successfully.
This is a temporary solution for now, but it allowed me to debug the issue more clearly while ensuring a reliable connection.
I hope this helps anyone facing the same problem!
