Hi, I tried to connect my raspberry to the knx through an IC00R01KNX.(the device software works). I setted the port to be disabled , added the row -Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0 in the script start.sh but the message still is:
Error connecting to KNX bus: Serial port ‘/dev/ttyAMA0’ could not be opened
in the configuration file:
knx:serialPort=/dev/ttyAMA0
there is a way to do openhab open this port?
thank you
Thanx for the responses guys, but the error perstists. Others ideas?
There is a way to read the feedback terminal dialog during the apt-get version execution as in the normal way with start.sh? thank you!
Thank you now I have seen that the problem is the same:
I don’t understand, I have done all what I had to do:
disabled the serial port AMA0
installed openhab through apt-get install
installed the boundles knx and serial and configured the serial communication with the port ttyAMA0
inserted ‘openhab’ in the dialout group
added the row -Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0 just after -Dosgi.noShutdown=true
Just for kicks and to put to bed the problem being a permissions problem change the permissions on /dev/ttyAMA0 to full read/write. The permissions will only stick until the next reboot which is why adding the openhab user to the dialout group is preferable.
The command is:
sudo chmod a+rwx /dev/ttyAMA0
Then restart openHAB and see if the error goes away. If it does then we know it is a permission problem. If it doesn’t then there is some other problem, perhaps the serial device is not working or something like that.
