My guess is, the “ON” feedback telegram leads to “100%”, then directly immedialty it changes to “50%”, which is kinda strange behaviour. Can I avoid that somehow?
Thank you so much for bringing up this question. This is something I’ve been wondering about for a long time as well. I’m also seeing this behaviour in my setup on both OH2 and OH3. Would be great to finally get an answer to that mystery.
So, why does the UI (and the channel configuration) allow the “switch”-state then for a “dimmer”-channel? shouldn’t this be removed then? or did I miss something here?
Maybe. There’s no reason that you cannot send a command OFF to a Dimmer Item, and see its state change to 0. There’s no reason you can’t have a Dimmer set to 10 and have a UI show that it is ON.
I don’t think it’s a state, I am most definitely sure it is an accepted command type. A dimmer item can receive command types such as OnOff, IncreaseDecrease, or Percent. The state is only Percent.
The first address deals with an ON/OFF command from openHAB and does whatever it needs to do for the device.
The inbound address <1/2/3 listens for on/off from the device, and does what it needs to do for openHAB. Because a Dimmer type has no on/off state at all, it must translate that to 0 or 100.
As O.P. points out, this is undesirable when you are also getting a separate “real” % value incoming.
So do away with, don’t listen to 1/2/3, just send on 1/2/0
The question remains whether the device really sends the separate % value under all circumstances. Try it.
OK, I’ll try that… but I could swear, I didn’t have those strange updates with KNX1…?
nonetheless: one thing is not clear to me and I just read through my GIRA actuator.
the Actuator does react on ON/OFF (channel1, function “switch”: DPT 1.001)
the Actuator does react on Increase/Decrease (channel1, function “dim”: DPT 3.007)
the Actuator does react on a percentage (channel1, function “brightness value”: DPT 5.001)
then again
the Actuator sends feedback to ON/OFF (channel1, function “feedback switch”: DPT 1.001)
the Actuator sends feedback to a percentage (channel1, function feedback brightness value": DPT 5.001)
I use 1/2/3 in my KNX sensor, and it will show in a LED, whether the light is ON (regardless, if it is 1% or 100%).
So, I’d expect to behave the actual dimmer-channel in the KNX-binding exactly the same way? My Actuator is a GIRA dim actuator, but I also read some docu on a Mertens, and this one is also doing the same exact thing?
I removed the listening GA for the switch (1/2/3) and now it doesn’t have those crazy updates anymore, if the actuator sends its regular state telegrams…
So it means, that I can send ON/OFF to the OH-switch, but I can’t read ON/OFF out of it…
The idea is that you don’t need to. If a Dimmer Item state is 0,it’s the equivalent of OFF. If it’s state 1-100, it’s ON. That is the only information that you can hold in a Dimmer type Item, no matter how you configure it.
