Hi, I have a problem after update:
[ERROR] [KNXnet/IP Tunneling 192.168.0.4:3671] - establishing connection failed, timeout connecting to control endpoint 192.168.0.4:3671
2022-08-01 18:19:17.267 [DEBUG] [nx.internal.client.AbstractKNXClient] - Error connecting to the bus: timeout connecting to control endpoint 192.168.0.4:3671
tuwien.auto.calimero.KNXTimeoutException: timeout connecting to control endpoint 192.168.0.4:3671
at tuwien.auto.calimero.knxnetip.ClientConnection.connect(ClientConnection.java:216) ~[?:?]
at tuwien.auto.calimero.knxnetip.KNXnetIPTunnel.(KNXnetIPTunnel.java:171) ~[?:?]
at tuwien.auto.calimero.knxnetip.KNXnetIPTunnel.(KNXnetIPTunnel.java:163) ~[?:?]
at org.openhab.binding.knx.internal.client.IPClient.getConnection(IPClient.java:110) ~[?:?]
at org.openhab.binding.knx.internal.client.IPClient.createKNXNetworkLinkIP(IPClient.java:93) ~[?:?]
at org.openhab.binding.knx.internal.client.IPClient.establishConnection(IPClient.java:80) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKNXClient.connect(AbstractKNXClient.java:179) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
2022-08-01 18:19:17.276 [DEBUG] [nx.internal.client.AbstractKNXClient] - Bridge knx:ip:bridge is disconnecting from the KNX bus
My thing is here:
Bridge knx:ip:bridge [
type="TUNNEL",
ipAddress="192.168.0.4",
portNumber=3671
Thing device generic "KNX QAX 913" [
address="0.2.254"
Type number : knx_door1_R "Dveře 1 (Garáž) " [ga="2.001:<0/4/6"]
Type number : knx_door2_R "Dveře 2 " [ga="2.001:<0/4/7"]
Type number : knx_light1_R "Světlo 1 " [ga="2.001:<0/4/8"]
Type number : knx_light2_R "Světlo 2 " [ga="2.001:<0/4/10"]
Type number : knx_light3_R "Světlo 3 " [ga="2.001:<0/4/11"]
Type number : knx_light4_R "Světlo 4 " [ga="2.001:<0/4/"]
When I downgrade to 3.2.0, it works flawlessly. Does anyone solve this kind of problem? Thank you for help.
