Right - I’m embarrassed to ask this question because I see it coming up so often (usually followed by a very patient answer by @Udo_Hartmann ) but for the life of me, I cannot seem to integrate it into my situation:
OpenHAB should own the state of the winter/summer switch:
Type switch-control : SummerMode "is Summer" [ ga="1/6/20" ]
My assumption is that since OpenHAB controls the state of SummerMode it will also respond to GroupValue_Read requests from the KNX bus. Correct?
I also setup my MDT heating controller to read the value of 1/6/20 but when testing in ETS5 I don’t see answers to read requests.
Would a mainGA that accepts read requests? I tried ga="<1/6/20" and I also tried ga="1/6/21+<1/6/20" and ga="1/6/21+<1/6/20" but I feel like I’m shooting in the dark… what’s the right way to have a group address that my heating actor can read that is only switched from within OpenHAB rules (no other KNX devices)?
@JuSt thanks for the comment - I’m using the following format to enable to me spread out my knx things across multiple files and reference back to knx:ip:knxrouter defined in one place. For example:
Well, in theory, openHAB should answer to read requests when it’s a *.control channel, but to be honest, I’ve never seen an answer to a read request from knx bus either.
As your bridge seems to be a knx/IP Router, is filtereing switched off?
for *-control channels, the first GA is the one which is used to answer read requests, so whgen using
a read request to 1/6/20 should be answered by openHAB.
