Java Runtime Environment: which java platform is used and what version
openHAB version: 2.1
Issue of the topic: I´m unable to connect to my KNX webserver from synco living OZW772. I tried Router connection, but I´m newbie and can´t find any system settings to connect device. Thank you in advance for an help.
Please post configurations (if applicable):
2018-03-15 20:56:55.415 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedService, id=302, bundle=192/mvn:org.openhab.binding/org.openhab.binding.knx/1.9.0]: Unexpected problem updating configuration org.openhab.knx
tuwien.auto.calimero.exception.KNXIllegalArgumentException: non-valid routing multicast /192.168.0.105
at tuwien.auto.calimero.knxnetip.KNXnetIPRouting.(KNXnetIPRouting.java:151)[192:org.openhab.binding.knx:1.9.0]
at tuwien.auto.calimero.knxnetip.KNXnetIPRouting.(KNXnetIPRouting.java:134)[192:org.openhab.binding.knx:1.9.0]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.(KNXNetworkLinkIP.java:154)[192:org.openhab.binding.knx:1.9.0]
at org.openhab.binding.knx.internal.connection.KNXConnection.connectByIp(KNXConnection.java:292)[192:org.openhab.binding.knx:1.9.0]
at org.openhab.binding.knx.internal.connection.KNXConnection.connect(KNXConnection.java:179)[192:org.openhab.binding.knx:1.9.0]
at org.openhab.binding.knx.internal.connection.KNXConnection.updated(KNXConnection.java:448)[192:org.openhab.binding.knx:1.9.0]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1461)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1417)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141)[3:org.apache.felix.configadmin:1.8.12]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109)[3:org.apache.felix.configadmin:1.8.12]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
2018-03-16 15:42:57.203 [ERROR] [tuwien.auto.calimero ] - KNXnet/IP Tunneling 192.168.0.105:443: communication failure on connect
java.io.IOException: Invalid argument (sendto failed)
at java.net.PlainDatagramSocketImpl.send(Native Method)[:1.8.0_121]
at java.net.DatagramSocket.send(DatagramSocket.java:693)[:1.8.0_121]
at tuwien.auto.calimero.knxnetip.ClientConnection.connect(ClientConnection.java:158)[192:org.openhab.binding.knx:1.9.0]
at tuwien.auto.calimero.knxnetip.KNXnetIPTunnel.(KNXnetIPTunnel.java:131)[192:org.openhab.binding.knx:1.9.0]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.(KNXNetworkLinkIP.java:142)[192:org.openhab.binding.knx:1.9.0]
at org.apache.felix.cm.impl.ConfigurationManager$UpdateConfiguration.run(ConfigurationManager.java:1772)[3:org.apache.felix.configadmin:1.8.12]
Items configuration related to the issue
Sitemap configuration related to the issue
Rules code related to the issue
Services configuration related to the issue
If logs where generated please post these here using code fences:
