A question on KNX…I’ve got all my KNX lighting working really well via openhab and google home…Status & Switching. I’ve also got my thermostats being read too.
Now, I want to go a little further with the Thermostats and try to set them. Is this possible? Anyone had success setting the target temperature? I assume I need to expose more of the GAs for the devices that I need to set the target temperature for.
@Dim - I know you are good at this stuff any ideas?
Pete
And YES - that’s working perfectly!!! I can move the temp up and down and the new values appear on my Gira app and the screen on my temp switches on the wall - nice one! Thanks @Zijl
Only think is it doesn’t show the current status (ie, temp). I think i may be missing something to get the current temp back when I re-load the items map. It seems to take a very long time to update the temperatures.
If it does sent back on the setTemp ga, you need to check if the read flag is set in ETS. If not, you can reference more than one ga in OH: ga= “9.001:2/1/6+<2/1/5” for example.
