Hello Guys. Trying to get my OH3 and KNX up and running. I’ve added the Binding, and it seems to be connected to the KNX bus.
But then i wanna add some things/channels to that binding, and here i can’t figure out what’s causing the problem…
Earlier i used the very old way, where items was created directly with KNX addreses…
If i go to my “Thing” and “Code” for the KNX module i get following:
UID: knx:ip:4cd99b16c5
label: KNX
thingTypeUID: knx:ip
configuration:
useNAT: false
readRetriesLimit: 3
ipAddress: 224.0.23.12
autoReconnectPeriod: 60
type: ROUTER
localSourceAddr: 1.1.254
readingPause: 50
portNumber: 3671
responseTimeout: 10
Thing device 100_ON_OFF “100 ON/OFF aktuator” @ “KNX” [ address=“1.1.200”, fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Ch_A “Channel A” [ ga= “0/3/6” ]
Type switch : Ch_C “Channel C” [ ga= “0/5/10” ]
Type switch : Ch_D “Channel D” [ ga= “0/2/12” ]
Type switch : Ch_E “Channel E” [ ga= “0/4/0” ]
Type switch : Ch_F “Channel F” [ ga= “0/4/0+<0/4/1” ]
Type switch : Ch_G “Channel G” [ ga= “2/0/0” ]
Type switch : Ch_H “Channel H” [ ga= “2/1/5+<2/1/6” ]
Type switch : Ch_I “Channel I” [ ga= “2/0/20+<2/0/21” ]
Type switch : Ch_J “Channel J” [ ga= “2/0/10+<2/0/11” ]
Type switch : Ch_K “Channel K” [ ga= “2/1/10+<2/1/11” ]
The first part setting up the configuration is generated automatically from the binding - then i try inserted the Thing 100_On_OFF - and then it got mad at me
