mobil750
(Helmut Richter)
October 10, 2023, 10:45am
1
I have an issue with a single KNX Thing which worked well over years in OH3.x. Since upgrading to OH 4.02 it doesn’t work no longer. The Upgrade was done via backup OH 3, complete new installation of OH 4 and then restoring the OH 3 configuration. All worked well immediately except one Thing.
For this I get
“HANDLER_INITIALIZING_ERROR
Index 0 out of bounds for length 0”
Log file:
changed from UNINITIALIZED (HANDLER_INITIALIZING_ERROR): Index 0 out of bounds for length 0 to UNINITIALIZED (HANDLER_MISSING_ERROR)
I created a new thing for this device which was immediately initialized and reported as online.
Then I defined all channels.
Unlinked the Items of the old Thing and linked them to the new Thing/Channels.
The Thing was still online but the Items didn’t got updated.
So I disabled the new Thing and reenabled it.
The result is now the same as with the old Thing (deleted). Same error as above …
Can anyone help me to get this issue solved?
Thanks a lot in advance.
Helmut
J-N-K
(Jan N. Klug)
October 10, 2023, 11:25am
2
Please show the thing as code view
mobil750
(Helmut Richter)
October 10, 2023, 11:47am
3
Thanks for the quick response. Here the code …
UID: knx:device:ccc7b32f9f:3c211ef4ef
label: KNX Device KG TR Rauchwarnmeldezentrale
thingTypeUID: knx:device
configuration:
pingInterval: 600
readInterval: 0
fetch: false
bridgeUID: knx:ip:ccc7b32f9f
channels:
- id: CH_KG_Technikraum_RWM_Heartbeats
channelTypeUID: knx:number
label: CH KG Technikraum Heartbeat Zähler
description: ""
configuration:
ga: 7.010:<15/7/13
- id: CH_KG_Technikraum_RWM_Bitmap_aktive_Alarme
label: CH KG Technikraum RWM Bitmap aktive Alarme
description: ""
configuration:
ga: 7.010:<15/7/11
- id: CH_KG_Technikraum_RWM_Bitmap_aktivierte_Inputs
label: CH KG Technikraum RWM Bitmap aktivierte Eingänge
description: ""
configuration:
ga: 7.010:<15/7/10
- id: CH_KG_Technikraum_RWM_Bitmap_aktivierten_Outputs
label: CH KG Technikraum RWM Bitmap aktivierter Ausgänge
description: ""
configuration:
ga: 7.010:<15/7/12
- id: CH_KG_Technikraum_RWM_Spannung_Notfallbatterie
label: CH KG Technikraum RWM Spannung Notfallbatterie
description: ""
configuration:
ga: 9.020<15/7/15
- id: CH_KG_Technikraum_RWM_Bitmap_Status_AUX
label: CH KG Technikraum RWM Bitmap Status und AUX Eingänge
description: ""
configuration:
ga: 7.010:<15/7/14
- id: CH_KG_TR_RWM_1
channelTypeUID: knx:switch
label: CH KG TR RWM 1
description: ""
configuration:
ga: 1.011:15/7/16
- id: CH_KG_TR_RWM_2
label: CH KG TR RWM 2
description: ""
configuration:
ga: 1.011:<15/7/17
- id: CH_KG_TR_RWM_5
label: CH KG TR RWM 5
description: ""
configuration:
ga: 1.001:<15/7/20
- id: CH_KG_TR_RWM_6
label: CH KG TR RWM 6
description: ""
configuration:
ga: 1.001:<15/7/21
- id: CH_KG_TR_RWM_7
label: CH KG TR RWM 7
description: ""
configuration:
ga: 1.001:<15/7/22
- id: CH_KG_TR_RWM_8
label: CH KG TR RWM 8
description: ""
configuration:
ga: 1.001:<15/7/23
- id: CH_KG_TR_RWM_9
label: CH KG TR RWM 9
description: ""
configuration:
ga: 1.001:<15/7/24
- id: CH_KG_TR_RWM_10
label: CH KG TR RWM 10
description: ""
configuration:
ga: 1.001:<15/7/25
- id: CH_KG_TR_RWM_11
label: CH KG TR RWM 11
description: ""
configuration:
ga: 1.001:<15/7/26
- id: CH_KG_TR_RWM_12
label: CH KG TR RWM 12
description: ""
configuration:
ga: 1.001:<15/7/27
- id: CH_KG_TR_RWM_3
label: CH KG TR RWM 3
description: ""
configuration:
ga: 1.001:<15/7/18
- id: CH_KG_TR_RWM_4
label: CH KG TR RWM 4
description: ""
configuration:
ga: 1.001:<15/7/19
- id: CH_KG_TR_RWMZ_Alarm
channelTypeUID: knx:contact
label: CH KG TR RWMZ Alarm
description: ""
configuration:
ga: <15/7/28
J-N-K
(Jan N. Klug)
October 10, 2023, 12:29pm
5
9.020<15/7/15
is not a valid definition, it lacks the :
separator between the DPT and the GA.
This is also in the log:
14:25:02.162 [WARN ] [nal.channel.GroupAddressConfiguration] - Failed parsing channel configuration '9.020<15/7/15'.
mobil750
(Helmut Richter)
October 10, 2023, 2:06pm
6
Thanks a lot! That was realy great help!
Helmut
