Hello everybody,
whilst I was able to sort out the weird behaviour of the OH2 KNX Binding by omitting the local address, I still see some errors occur every two hours.
Yesterday 20:36 (full log)…
2019-05-04 20:36:05.184 [WARN ] [Xnet/IP Tunneling 192.168.20.27:3671] - response timeout waiting for confirmation
tuwien.auto.calimero.KNXTimeoutException: no confirmation reply received for 0.0.0->1.0.9 L_Data.req, system priority hop count 6 repeat, tpdu 81
at tuwien.auto.calimero.knxnetip.ClientConnection.doExtraBlockingModes(ClientConnection.java:244) ~[240:org.openhab.binding.knx:2.4.0]
at tuwien.auto.calimero.knxnetip.ConnectionBase.send(ConnectionBase.java:258) ~[240:org.openhab.binding.knx:2.4.0]
at tuwien.auto.calimero.knxnetip.KNXnetIPTunnel.send(KNXnetIPTunnel.java:178) ~[240:org.openhab.binding.knx:2.4.0]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.onSend(KNXNetworkLinkIP.java:243) ~[240:org.openhab.binding.knx:2.4.0]
at tuwien.auto.calimero.link.AbstractLink.send(AbstractLink.java:351) ~[240:org.openhab.binding.knx:2.4.0]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.sendRequestWait(KNXNetworkLinkIP.java:222) ~[240:org.openhab.binding.knx:2.4.0]
at tuwien.auto.calimero.mgmt.TransportLayerImpl.sendDisconnect(TransportLayerImpl.java:612) ~[240:org.openhab.binding.knx:2.4.0]
at tuwien.auto.calimero.mgmt.TransportLayerImpl.handleConnected(TransportLayerImpl.java:510) ~[240:org.openhab.binding.knx:2.4.0]
at tuwien.auto.calimero.mgmt.TransportLayerImpl.access$400(TransportLayerImpl.java:87) ~[240:org.openhab.binding.knx:2.4.0]
at tuwien.auto.calimero.mgmt.TransportLayerImpl$NLListener.indication(TransportLayerImpl.java:127) ~[240:org.openhab.binding.knx:2.4.0]
at tuwien.auto.calimero.link.AbstractLink$LinkNotifier.lambda$frameReceived$1(AbstractLink.java:159) ~[240:org.openhab.binding.knx:2.4.0]
at tuwien.auto.calimero.internal.EventListeners.fire(EventListeners.java:129) [240:org.openhab.binding.knx:2.4.0]
at tuwien.auto.calimero.link.EventNotifier.fire(EventNotifier.java:164) [240:org.openhab.binding.knx:2.4.0]
at tuwien.auto.calimero.link.EventNotifier.run(EventNotifier.java:101) [240:org.openhab.binding.knx:2.4.0]
2019-05-04 20:36:05.192 [WARN ] [calimero.mgmt.TL 192.168.20.27:3671 ] - disconnected not gracefully (timeout)
Then again at 23:56 (I leave out all the “at tuwin.auto.calimero…” lines from here onward)
2019-05-04 23:56:11.917 [WARN ] [Xnet/IP Tunneling 192.168.20.27:3671] - response timeout waiting for confirmation
tuwien.auto.calimero.KNXTimeoutException: no confirmation reply received for 0.0.0->1.0.2 L_Data.req, system priority hop count 6 repeat, tpdu 81
2019-05-04 23:56:11.925 [WARN ] [calimero.mgmt.TL 192.168.20.27:3671 ] - disconnected not gracefully (timeout)
And finally at 01:36 and 03:36 (compressed now to only the WARN lines)
2019-05-05 01:36:14.967 [WARN ] [Xnet/IP Tunneling 192.168.20.27:3671] - response timeout waiting for confirmation
2019-05-05 01:36:14.973 [WARN ] [calimero.mgmt.TL 192.168.20.27:3671 ] - disconnected not gracefully (timeout)
2019-05-05 03:36:22.823 [WARN ] [Xnet/IP Tunneling 192.168.20.27:3671] - response timeout waiting for confirmation
2019-05-05 03:36:22.832 [WARN ] [calimero.mgmt.TL 192.168.20.27:3671 ] - disconnected not gracefully (timeout)
This is my knx config:
Bridge knx:ip:bridge [
ipAddress="192.168.20.27",
portNumber=3671,
localIp="192.168.20.13",
type="TUNNEL",
readingPause=50,
responseTimeout=10,
readRetriesLimit=3,
autoReconnectPeriod=1
//localSourceAddr="15.15.254"
localSourceAddr is commented out as it caused a lot of trouble when the local address has been taken by any other component (the Weinzierl Gateway provisions them on a first come-first served basis).
Any Idea how to get rid of these warnings?
Best
Hans
