I’m experiencing strange KNX-WARNings out of the blue. I didn’t change anything (items or knx.cfg) - Yesterday the KNX binding worked fine without having those strange WARNings, beginning with an reconnect at 6:11 (no incidents beforehand - and I was just in the bathroom at that time! )
2018-01-15 06:11:27.563 [WARN ] [nx.internal.connection.KNXConnection] - KNX link has been lost (reason: server request on object tunneling link link (closed) 192.168.xx.6:3671 TP1 medium, device 0.0.0, hopcount 6)
2018-01-15 06:11:27.568 [INFO ] [nx.internal.connection.KNXConnection] - KNX link will be retried in 10 seconds
2018-01-15 06:11:27.594 [WARN ] [nx.internal.connection.KNXConnection] - KNX link has been lost (reason: server request on object tunneling link link (closed) 192.168.xx.6:3671 TP1 medium, device 0.0.0, hopcount 6)
2018-01-15 06:11:27.599 [INFO ] [nx.internal.connection.KNXConnection] - KNX link will be retried in 10 seconds
2018-01-15 06:11:27.686 [ERROR] [.binding.knx.internal.bus.KNXBinding] - Received detach Event.
2018-01-15 06:11:37.579 [INFO ] [nx.internal.connection.KNXConnection] - Trying to (re-)connect to KNX...
2018-01-15 06:11:37.608 [INFO ] [nx.internal.connection.KNXConnection] - Established connection to KNX bus on 192.168.178.6:3671 in mode TUNNEL.
2018-01-15 06:11:37.631 [INFO ] [nx.internal.connection.KNXConnection] - Connected to KNX
2018-01-15 06:11:37.685 [INFO ] [nx.internal.connection.KNXConnection] - Trying to (re-)connect to KNX...
2018-01-15 06:11:37.729 [INFO ] [nx.internal.connection.KNXConnection] - Established connection to KNX bus on 192.168.178.6:3671 in mode TUNNEL.
2018-01-15 06:11:37.739 [INFO ] [nx.internal.connection.KNXConnection] - Connected to KNX
2018-01-15 06:11:40.651 [WARN ] [al.bus.KNXBindingDatapointReaderTask] - Autorefresh: Cannot read value for item 'RTR_OG_KiZiWest_setTemp' from KNX bus: no confirmation reply received for L-Data.req from 0.0.255 to 8/2/33, low priority hop count 6 repeat tpdu 00 00: timeout
2018-01-15 06:11:40.649 [WARN ] [tuwien.auto.calimero ] - KNXnet/IP Tunneling 192.168.xxx.6:3671: response timeout waiting for confirmation
tuwien.auto.calimero.exception.KNXTimeoutException: no confirmation reply received for L-Data.req from 0.0.255 to 8/2/33, low priority hop count 6 repeat tpdu 00 00
at tuwien.auto.calimero.knxnetip.ClientConnection.doExtraBlockingModes(ClientConnection.java:236) [218:org.openhab.binding.knx:1.11.0]
at tuwien.auto.calimero.knxnetip.ConnectionBase.send(ConnectionBase.java:269) [218:org.openhab.binding.knx:1.11.0]
at tuwien.auto.calimero.knxnetip.KNXnetIPTunnel.send(KNXnetIPTunnel.java:149) [218:org.openhab.binding.knx:1.11.0]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.onSend(KNXNetworkLinkIP.java:263) [218:org.openhab.binding.knx:1.11.0]
at tuwien.auto.calimero.link.AbstractLink.send(AbstractLink.java:304) [218:org.openhab.binding.knx:1.11.0]
at tuwien.auto.calimero.link.KNXNetworkLinkIP.sendRequestWait(KNXNetworkLinkIP.java:240) [218:org.openhab.binding.knx:1.11.0]
at tuwien.auto.calimero.process.ProcessCommunicatorImpl.readFromGroup(ProcessCommunicatorImpl.java:486) [218:org.openhab.binding.knx:1.11.0]
at tuwien.auto.calimero.process.ProcessCommunicatorImpl.read(ProcessCommunicatorImpl.java:422) [218:org.openhab.binding.knx:1.11.0]
at org.openhab.binding.knx.internal.bus.KNXBindingDatapointReaderTask.readFromKNXBus(KNXBindingDatapointReaderTask.java:99) [218:org.openhab.binding.knx:1.11.0]
at org.openhab.binding.knx.internal.bus.KNXBindingDatapointReaderTask.run(KNXBindingDatapointReaderTask.java:67) [218:org.openhab.binding.knx:1.11.0]
2018-01-15 06:11:40.685 [WARN ] [al.bus.KNXBindingDatapointReaderTask] - Autorefresh: Remaining retries for address '8/2/33' = '2'
2018-01-15 06:11:40.964 [ERROR] [nternal.connection.OneWireConnection] - Writing -3.7800000000000002 to path 26.E1CD92010000/temperature attempt 1 threw an exception
org.owfs.jowfsclient.OwfsException: Error -95
at org.owfs.jowfsclient.internal.OwfsConnectionImpl.readPacket(OwfsConnectionImpl.java:264) [231:org.openhab.binding.onewire:1.11.0]
at org.owfs.jowfsclient.internal.OwfsConnectionImpl.write(OwfsConnectionImpl.java:150) [231:org.openhab.binding.onewire:1.11.0]
at org.openhab.binding.onewire.internal.connection.OneWireConnection.writeToOneWire(OneWireConnection.java:348) [231:org.openhab.binding.onewire:1.11.0]
at org.openhab.binding.onewire.internal.OneWireBinding.internalReceiveCommand(OneWireBinding.java:134) [231:org.openhab.binding.onewire:1.11.0]
at org.openhab.core.binding.AbstractBinding.receiveCommand(AbstractBinding.java:94) [200:org.openhab.core.compat1x:2.2.0]
at org.openhab.core.events.AbstractEventSubscriber.handleEvent(AbstractEventSubscriber.java:45) [200:org.openhab.core.compat1x:2.2.0]
at org.apache.felix.eventadmin.impl.handler.EventHandlerProxy.sendEvent(EventHandlerProxy.java:415) [3:org.apache.karaf.services.eventadmin:4.1.3]
at org.apache.felix.eventadmin.impl.tasks.HandlerTask.runWithoutBlacklistTiming(HandlerTask.java:82) [3:org.apache.karaf.services.eventadmin:4.1.3]
at org.apache.felix.eventadmin.impl.tasks.SyncDeliverTasks.execute(SyncDeliverTasks.java:104) [3:org.apache.karaf.services.eventadmin:4.1.3]
at org.apache.felix.eventadmin.impl.tasks.AsyncDeliverTasks$TaskExecuter.run(AsyncDeliverTasks.java:166) [3:org.apache.karaf.services.eventadmin:4.1.3]
2018-01-15 06:11:40.977 [INFO ] [nternal.connection.OneWireConnection] - Trying to reconnect to owserver...
2018-01-15 06:11:41.197 [INFO ] [nternal.connection.OneWireConnection] - Connected to owserver [IP '127.0.0.1' Port '4304']
2018-01-15 06:11:41.313 [ERROR] [nternal.connection.OneWireConnection] - Writing -3.7800000000000002 to path 26.E1CD92010000/temperature attempt 2 threw an exception
hint: one item gets updated via onewire - and sends it’s content to KNX, I don’t know, why openHAB wanted to write to the onewire?
then it goes on and on:
2018-01-15 14:39:04.302 [WARN ] [.binding.knx.internal.bus.KNXBinding] - Value '4.5' could not be sent to the KNX bus using datapoint 'command DP 0/3/1 Sensoren_OktTemp_OutN, DPT main 0 id 9.001, low priority' - retrying one time: no confirmation reply received for L-Data.req from 0.0.255 to 0/3/1, low priority hop count 6 repeat tpdu 00 80 01 c2
the item in this WARNing is (gets updated via MQTT-eventbus):
Number Sensoren_OktTemp_OutN "Temperatur Nord [%.1f °C]" (gOktopusTemp, UG_Oktopus) { expire="5m", knx="9.001:0/3/1" }
