hope you can help, I am a little bit at a loss here.
So - I configured a Velux rollershutter to work with my OH2 installation. Which works fine. Now, I’m trying to program a (physical) KNX switch to control the rollershutter - and that’s where I’m stuck.
Here’s what I’ve done and tried:
in the knx things there is the corresponding thing definition: Type rollershutter : GZ_OG_JD "GZ_OG_JD" [ upDown = "2/2/20", stopMove = "2/2/21", position = "<2/2/22" ]
In my items file, there is a corresponding item to this: Rollershutter GZ_OG_JD "Jalousie Gäste" (Shutter_OG) { channel="knx:device:bridge:generic:GZ_OG_JD" }
I’ve also mapped the group addresses (2/2/20 ff) to the physical switch in KNX/ETS
Here is what happens:
when I control the rollershutter with the OH app, the shutter works as expected
when I try to control the shutter via the physical switch, nothing happens.
Some forensics:
When I press the physical button, the knx bus talks to the group address (I can see that in the diagnosis of ETS) - however, there is no event created in OpenHAB
Same thing when I press the button in the OH app - group address is triggered - additionally, an event is triggered in OpenHAB
I would’ve said that generally, knx will not send button presses to OH - however, I have another physical switch (which controls a light) where everything is working as expected.
That sort of did it - thanks.
However, while I do receive a value from knx now, it reads:
GZ_OG_JD changed from 0 to 100
when I press the physical switch. I have a rule which says:
rule "Jalousie zu"
Item GZ_OG_JD changed from 0 to 100
sendCommand(GZ_OG_UP, DOWN)
And a rule for up, too, of course.
However, this translates to a button switch either fully opens the shutter or fully close it - how can I configure the switch to properly control the shutter?
I’ve tried linking one item to two channels (knx and velux), but that doesn’t do anything…
Have a look in your events.log
Your xxx-control channel should be producing commands for your openHAB Item in response to poking buttons on the real device.
You’ll find the commands of interest, not the Item state.
I have started to use the knx binding 2.0 after switching to OH3. Unfortunately the readings do not work for me and I do not understand the reason.
I show this with the example of a push button interface which counts the pulses of a S0 interface and sends the value every 100 pulses:
Hi Daniel,
you are using DPT Type 13.001 but in OH you are using type number which is as per default DPT 9.001. Your are trying to write a 4 byte value into a 2 byte variable. You have to specify the type as written in the knx binding documentation.
Type number: Energieverbrauch_WP_S0_roh [ ga=“13.001:3/0/7” ]
Check out the link, explaining all types which are supported by the knx binding.
Thanks for your reply.
After your suggestet changes, the values seem to look in the right direction, but hey are still strange.
My s0 counter seems to flicker around in openhab, but doesn´t so when I look at the bus directly. I have no clue where the lower value is coming from.
Furthermore, since my change, the push button is shown as unintialized, but it seems to get the values somehow.
The Thing „Tasterinface“ is just a container, important is you have configured the group addresses correct. In the end you can also put every Group address in one KNX thing. The binding is listing to the group addresses and there is no compelling context to the device addresses in on your KNX network.
In OH 2.5 it was helpful to restart OH after the implementation of Changes within KNX group addresses, but in OH 3 I didn’t make this experience.
May be you can share the config of the WP-S0-roh value, although the ets one it seems you have continuing mismatch of types. Starting from zero looks like an overflow in the bytes.
