I’m using the caldav binding to control some of my automation. E.g. some of the roller shutters should go down in the evening.
Turns out that the binding seems to create the commands too fast for the KNX bus.
If I duplicate the entries in the calendar entry it works. It also works if I use a rule which delays by 250 milliseconds between each command.
That is quite annoying so my question: is there any setting in the KNX binding where I can define some delay in sending?
