has someone already successfully controlled the color temperature of a “tunable white” LED using the KNX 2 Binding?
I’m trying to use the MDT Dali 32 Control device and set the color temperature by writing DPT 7.600 (Kelvin).
Here is my setup:
Number ColorTemp "Light Family Temperature" {channel="knx:device:bridge:DaliControl:daliD1G1FamilyTemp" }
Thing device DaliControl [...] {
Type number : daliD1G1FamilyTemp "Family Room Temp" [ position="7.600:1/4/0+<3/2/0"]
The only result is a log file with a parsing fault:
2018-07-15 14:12:14.484 [INFO ] [g.knx.internal.dpt.KNXCoreTypeMapper] - Translator couldn’t parse data for datapoint type ‘7.600’ (KNXFormatException).
2018-07-15 14:12:14.485 [WARN ] [.internal.handler.DeviceThingHandler] - Ignoring KNX bus data: couldn’t transform to any Type (destination=‘3/2/0’, datapoint=‘command DP 3/2/0 ‘knx:device:bridge:DaliControl’, DPT id 7.600, low priority’, data=‘0x1250’)
Did I something wrong? Is 7.600 not supported so far? Other hints?
Thanks!
