I have a counter for my water consumption installed. Once I reset the counter, I get the date and time when the reset was done sent on the bus using 2 GA. One has GA 4/3/10 with DPT: 10.001 and holds the time. The other GA is 4/3/9 with DPT: 11.001 and contains the date. See KNX log for example:
Now I defined the things in OpenHAB as follows:
Thing device IMPZ1 "Impulzzaehler" @ "KNX" // [ address="1.1.17", fetch=false, pingInterval=300, readInterval=3600 ]
... some items before
Type datetime : Wasserzaehler_Reset_Zeit "Reset Verbrauchszähler Zeit [%1$tT]" [ga="10.001:4/3/10"]
Type datetime : Wasserzaehler_Reset_Datum "Reset Verbrauchszähler Datum [%1$td.%1$tm.%1$tY]" [ga="11.001:4/3/9"]
My items file contains both as separate items as well as a combined item:
DateTime Wasserzaehler_Reset_Zeit "Reset Verbrauchszähler Zeit [%1$tT]" {channel="knx:device:GIRA2168:IMPZ1:Wasserzaehler_Reset_Zeit"}
DateTime Wasserzaehler_Reset_Datum "Reset Verbrauchszähler Datum [%1$td.%1$tm.%1$tY]" {channel="knx:device:GIRA2168:IMPZ1:Wasserzaehler_Reset_Datum"}
DateTime Wasserzaehler_Reset_DateTime {channel="knx:device:GIRA2168:IMPZ1:Wasserzaehler_Reset_Datum,knx:device:GIRA2168:IMPZ1:Wasserzaehler_Reset_Zeit" }
Once the date and time objects are send to the bus, I can’t get the time (date is working fine). In the OpenHAB log I can see the following:
2018-09-03 19:34:23.350 [WARN ] [g.knx.internal.dpt.KNXCoreTypeMapper] - Could not parse '19:27:16' to a valid date
2018-09-03 19:34:23.351 [WARN ] [.internal.handler.DeviceThingHandler] - Ignoring KNX bus data: couldn't transform to any Type (destination='4/3/10', datapoint='command DP 4/3/10 'knx:device:GIRA2168:IMPZ1', DPT id 10.001, low priority', data='0x131B10')
I’m currently using OpenHAB 2.4-snapshot running on Docker.
Does anyone have an idea how to get the time saved into my thing/item?
Regards
Michel
