Hi there,
just wanted to ask if there’s a solution for this issue. It does not affect working with KNX2-binding, but it fills up my openhab.log once approximately 4-8mins after OH2 init/reboot. In the log there are between 80 and 130 occurances that are written in between 3 and 5 seconds within OH2’s runtime.
First (common) entry in the log-file;
2018-09-25 11:01:51.152 [INFO ] [egram.internal.TelegramActionService] - Bot [XXX] loaded from config file
As all log-entries are the very same (I’ve compared them punctually with Notepad++) I’m going to just attach the very first;
11:07:30.333 [WARN ] [calimero.mgmt.MC [GATEWAY-IP]:3671 ] - problem reading property (response 43 d6 00 01 00 00)
tuwien.auto.calimero.KNXRemoteException: property access OI 0 PID 1 failed/forbidden
at tuwien.auto.calimero.mgmt.ManagementClientImpl.extractPropertyElements(ManagementClientImpl.java:986) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementClientImpl.lambda$readProperty$0(ManagementClientImpl.java:570) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementClientImpl.waitForResponses(ManagementClientImpl.java:905) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementClientImpl.readProperty(ManagementClientImpl.java:568) ~[?:?]
at tuwien.auto.calimero.mgmt.ManagementClientImpl.readProperty(ManagementClientImpl.java:535) ~[?:?]
at org.openhab.binding.knx.internal.client.DeviceInfoClientImpl.lambda$2(DeviceInfoClientImpl.java:107) ~[?:?]
at org.openhab.binding.knx.internal.client.DeviceInfoClientImpl.readFromManagementClient(DeviceInfoClientImpl.java:56) ~[?:?]
at org.openhab.binding.knx.internal.client.DeviceInfoClientImpl.readDeviceProperties(DeviceInfoClientImpl.java:105) ~[?:?]
at org.openhab.binding.knx.internal.client.DeviceInspector.readDeviceProperties(DeviceInspector.java:97) ~[?:?]
at org.openhab.binding.knx.internal.client.DeviceInspector.readDeviceInfo(DeviceInspector.java:88) ~[?:?]
at org.openhab.binding.knx.handler.AbstractKNXThingHandler.describeDevice(AbstractKNXThingHandler.java:89) ~[?:?]
at org.openhab.binding.knx.handler.AbstractKNXThingHandler.lambda$0(AbstractKNXThingHandler.java:153) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
What I’ve done so far; I found a post of @Udo_Hartmann at Problem reading property so I’ve set all DPTs in my .things-file but the warnings still appear in the log.
For example, here’s the rollershutter right next to me;
Type rollershutter : Channel_J1_04 "Channel J1.04 - OG / Büro / Fenster Ost" [ upDown="1.008:3/2/80", stopMove="1.010:3/2/81", position="5.001:3/2/82+<3/2/86" ]
Also, I double-checked that all channels on my actuators, that are read by OH are actually read-able.
Anyone else facing/faced that issue? Many thanks in advance & BR,
Christian
