I had decided to give the KNX2 Binding a second Chance and sat up my devices all new.
Using the most recent 2.4 nightly Build and a Enertex router to my KNX bus.
So far, the shutters work well but the Position Object behaves strangely:
The very second a shutter starts moving, the Position jumps to 100%. After the shutter has stopped, it then jumps to the respective (correct) value. This can be seen with different RL actuators, which are even from different Brands.
Looking a the KNX Group monitor, everything is correct. The actuator never sends anything when starting to move (eg no “100%” value) but only after stopping the respective value is sent. With only OH2 on the bus, no echos as well.
Even more strange: Within PaperUI the state of one channel gets only updated with the correct value, after I have clicked on annother rollershutter. I can’t help, but it seems there is something really broken with the rollershutter stuff in KNX2… any ideas ?
Frank
knx.things
Bridge knx:ip:KNXRouter "Enertex KNX/IP Router" @ "KNX" [
type="ROUTER",
portNumber=3671,
readingPause=50,
responseTimeout=10,
readRetriesLimit=3,
autoReconnectPeriod=1,
localSourceAddr="1.1.55" ]
Thing device GENERIC "Scenes and Commands" @ "KNX"
Type number-control : Scenes "Szenen" [ ga="17.001:0/1/0" ]
Type switch : Presence "Anwesenheit" [ ga="<0/0/8" ]
Type switch : Night "Nachtobjekt" [ ga="<0/0/12" ]
// Type switch : Day "Tagobjekt" [ ga="<0/0/13" ]
Type switch : Absence "Abwesenheit" [ ga="<0/0/14" ]
Type switch-control : ShadingHouse "Beschattung_Haus" [ ga="4/0/0" ]
Type switch-control : ShadingEast "Beschattung_Ost" [ ga="4/0/1" ]
Type switch-control : ShadingSouth "Beschattung_Sued" [ ga="4/0/2" ]
Type switch-control : ShadingWest "Beschattung_West" [ ga="4/0/3" ]
Type switch-control : ShadingAuto "Beschattung_Automatik" [ ga="4/0/15" ]
Type switch-control : ShadingLockPosition "Beschattung absolute Pos. sperren" [ ga="4/0/16" ]
Type switch-control : ShadingStateKitchenEast "Beschattung_Status_Kueche_Ost" [ ga="1.011:6/7/1" ]
Type switch-control : ShadingStateLivingEast "Beschattung_Status_Wohnen_Ost" [ ga="1.011:6/7/2" ]
Type switch-control : ShadingStateLivingSouth "Beschattung_Status_Wohnen_Sued" [ ga="1.011:6/7/3" ]
Type switch-control : ShadingStateBalcony "Beschattung_Status_Balkon" [ ga="1.011:6/7/4" ]
Type switch-control : ShadingStateBedroom "Beschattung_Status_Schlafen" [ ga="1.011:6/7/5" ]
Type rollershutter-control : RSGroupHouseAll "RL_Haus_Alles" [ upDown="3/1/16", stopMove="3/2/16", position="3/2/16+3/5/16" ]
Type rollershutter-control : RSGroupEGAll "RL_EG_Alles" [ upDown="3/1/33", stopMove="3/2/33", position="3/2/33+3/5/33" ]
Type rollershutter-control : RSGroupOGAll "RL_OG_Alles" [ upDown="3/1/32", stopMove="3/2/32", position="3/2/32+3/5/32" ]
Type rollershutter-control : RSGroupEastAll "RL_Ost_Alles" [ upDown="3/1/17", stopMove="3/2/17", position="3/2/17+3/5/17" ]
Type rollershutter-control : RSGroupSouthAll "RL_Sued_Alles" [ upDown="3/1/18", stopMove="3/2/18", position="3/2/18+3/5/18" ]
Type rollershutter-control : RSGroupWestAll "RL_West_Alles" [ upDown="3/1/19", stopMove="3/2/19", position="3/2/19+3/5/19" ]
Type switch-control : CentralOff "Zentral-Aus EG" [ ga="0/0/4" ]
Thing device MEASURES "Sensor Data" @ "KNX"
Type number : TempOutsideSouth "Temperatur Aussen Süd" [ ga="9.001:<11/2/20"]
Type number : TempOutsideNorth "Temperatur Aussen Nord" [ ga="9.001:<11/2/22"]
Type number : HumidityOutside "Feuchte Aussen Süd" [ ga="9.001:<11/3/20"]
Type number : TempOffice "Temperatur Büro" [ ga="9.001:<11/2/7"]
Type number : HumidityOffice "Feuchte Büro" [ ga="9.001:<10/0/7"]
Type number : TempLibrary "Temperatur Bibliothek" [ ga="9.001:<11/2/5"]
Type number : TempLiving "Temperatur Wohnzimmer" [ ga="9.001:<11/2/1"]
Type number : TempSupplyroom "Temperatur Vorratskeller" [ ga="9.001:<11/2/17"]
Type number : HumiditySupplyroom "Feuchte Vorratskeller" [ ga="9.001:<10/0/17"]
Type number : BrightnessEast "Helligkeit Ost" [ ga="9.004:<11/1/19"]
Type number : BrightnessSouth "Helligkeit Süd" [ ga="9.004:<11/1/20"]
Type number : BrightnessWest "Helligkeit West" [ ga="9.004:<11/1/21"]
Type number : Dusk "Dämmerung" [ ga="9.004:<11/1/23"]
Thing device SA2JUNGREG "SA2 Jung Heizkeller" @ "KNX" [ address="1.1.2", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Channel01 "Licht Küche" [ ga="1/1/0+<1/4/0" ]
Type switch : Channel02 "Licht Unterschrank Nord" [ ga="1/1/2+<1/4/2" ]
Type switch : Channel03 "Steckdose Esse" [ ga="2/1/0+<2/4/0" ]
Type switch : Channel04 "Licht Unterschrank West" [ ga="1/1/3+<1/4/3" ]
Type switch : Channel05 "Wohnen Wandlampe West Links" [ ga="1/1/8+<1/4/8" ]
Type switch : Channel06 "Wohnen Wandlampe West Rechts" [ ga="1/1/9+<1/4/9" ]
Type switch : Channel07 "Licht Garten" [ ga="1/1/24+<1/4/24" ]
Type switch : Channel08 "Licht Balkon" [ ga="1/1/25+<1/4/25" ]
Thing device SA3JUNGREG "SA3 Jung Heizkeller" @ "KNX" [ address="1.1.3", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Channel01 "Licht Flur UG" [ ga="1/1/52+<1/4/52" ]
Type switch : Channel02 "Steckdose Heizkeller UG" [ ga="2/1/22+<2/4/22" ]
Thing device SA3JUNGREGC "SA3 Jung (Strommessung) Heizkeller - Current" @ "KNX" [ address="1.1.3", fetch=false, pingInterval=600, readInterval=120 ]
Type number : Channel01C "Steckdose Heizkeller UG" [ ga="9.021:<2/2/22" ]
Thing device SA5ABBREG "SA5 ABB Unterverteilung" @ "KNX" [ address="1.1.4", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Channel01 "Licht Treppenhaus" [ ga="1/1/18+<1/4/18" ]
Type switch : Channel01T "Licht Treppenhaus Zeit" [ ga="1/0/18+<1/4/18" ]
Thing device DA1THEBENREG "DA1 Theben Dimmer Heizkeller" @ "KNX" [ address="1.1.5", fetch=false, pingInterval=600, readInterval=0 ]
Type dimmer : Channel01 "Wohnen Licht Decke Flur EG" [ switch="1/1/4+<1/4/4", position="1/3/4+<1/5/4", increaseDecrease="1/2/4" ]
Type dimmer : Channel02 "Wohnen Wandlampen Ost" [ switch="1/1/45+<1/4/45", position="1/3/45+<1/5/45", increaseDecrease="1/2/45" ]
Type dimmer : Channel03 "Licht Esstisch" [ switch="1/1/10+<1/4/10", position="1/3/10+<1/5/10", increaseDecrease="1/2/10" ]
Thing device SA6MDTREG "SA6 MDT Unterverteilung" @ "KNX" [ address="1.1.6", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Channel01 "Steckdose Waschmaschine" [ ga="2/1/13+<2/4/13" ]
Type switch : Channel02 "Steckdose Trockner" [ ga="2/1/14+<2/4/14" ]
Type switch : Channel03 "Steckdose Geschirrspüler" [ ga="2/1/2+<2/4/2" ]
Thing device SA6MDTREGC "SA6 MDT (Strommessung) Unterverteilung" @ "KNX" [ address="1.1.6", fetch=false, pingInterval=600, readInterval=0 ]
Type number : Channel01C "Strom Steckdose Waschmaschine" [ ga="9.021:<2/5/13" ]
Type number : Channel02C "Strom Steckdose Trockner" [ ga="9.021:<2/5/14" ]
Type number : Channel03C "Strom Steckdose Geschirrspüler" [ ga="9.021:<2/5/2" ]
Thing device SA7JUNGUP "SA7 Jung UP Bibliothek" @ "KNX" [ address="1.1.20", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Channel01 "Steckdose West" [ ga="1/1/26+1.011:<1/4/26" ]
Thing device SA8MDTUP "SA8 MDT UP Licht Gästebett und Indirekt" @ "KNX" [ address="1.1.21", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Channel01 "Licht Gästebett" [ ga="1/1/28+1.011:<1/4/28" ]
Type switch : Channel02 "Indirekte Beleuchtung" [ ga="1/1/27+1.011:<1/4/27" ]
Thing device SA9MDTUP "SA09 MDT UP SD Bibliothek Ost" @ "KNX" [ address="1.1.22", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Channel01 "SD Bibliothek Ost" [ ga="2/1/17+1.011:2/4/17" ]
Thing device SA10MDTUP "SA10 MDT UP SD Bibliothek Süd" @ "KNX" [ address="1.1.23", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Channel01 "SD Bibliothek Süd" [ ga="2/1/16+1.011:2/4/16" ]
Thing device SA12MDTUP "SA12 MDT UP Licht Kellertreppe und Waschküche" @ "KNX" [ address="1.1.25", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Channel01 "Licht Kellertreppe" [ ga="1/1/19+<1/4/19" ]
Type switch : Channel02 "Licht Waschküche" [ ga="1/1/20+<1/4/20" ]
Thing device SA13MDTUP "SA13 MDT UP SD WoZi Nord-Ost" @ "KNX" [ address="1.1.27", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Channel01 "Wohnen Steckdose Nord-Ost" [ ga="2/1/3+<2/4/3" ]
Thing device SA14MDTUP "SA14 MDT UP SD WoZi Süd-Ost" @ "KNX" [ address="1.1.28", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Channel01 "Wohnen Steckdose Süd-Ost" [ ga="2/1/4+<2/4/4" ]
Thing device SA15MDTUP "SA15 MDT UP SD WoZi Süd" @ "KNX" [ address="1.1.29", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Channel01 "Wohnen Steckdose Süd" [ ga="2/1/5+<2/4/5" ]
Thing device SA16MDTUP "SA16 MDT UP Treppenhaus" @ "KNX" [ address="1.1.31", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Channel01 "Licht Treppenhaus" [ ga="1/1/18+<1/4/21" ]
Type switch : Channel01T "Licht Treppenhaus Zeit" [ ga="1/0/18+<1/4/21" ]
Type switch : Channel02 "Aussenlicht Treppenhaus" [ ga="1/1/22+<1/4/22" ]
Type switch : Channel03 "Licht Garage" [ ga="1/1/23+<1/4/23" ]
Thing device SA17JUNGUP "SA17 Jung UP Treppenhaus oben" @ "KNX" [ address="1.1.32", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Channel01 "Steckdose Treppenhaus Oben" [ ga="2/1/12+<2/4/12" ]
Thing device RA1MDTREG "RA1 MDT Rolladenaktor Heizkeller" @ "KNX" [ address="1.1.60", fetch=false, pingInterval=600, readInterval=0 ]
Type rollershutter : Channel01 "Rolladen Küche Ost" [ upDown="3/1/1", stopMove="3/2/1", position="5.001:3/3/1+<3/5/1" ]
Type rollershutter : Channel02 "Rolladen Wohnzimmer Ost" [ upDown="3/1/2", stopMove="3/2/2", position="5.001:3/3/2+<3/5/2" ]
Type rollershutter : Channel03 "Rolladen Wohnzimmer Süd" [ upDown="3/1/3", stopMove="3/2/3", position="5.001:3/3/3+<3/5/3" ]
Type rollershutter : Channel04 "Rolladen Balkontür" [ upDown="3/1/4", stopMove="3/2/4", position="5.001:3/3/4+<3/5/4" ]
Thing device RA2JUNGUP "RA2 Jung Rolladenaktor UP Treppenhaus" @ "KNX" [ address="1.1.61", fetch=false, pingInterval=600, readInterval=0 ]
Type rollershutter : Channel01 "Rolladen Treppenhaus" [ upDown="3/1/8", stopMove="3/2/8", position="5.001:3/3/8+<3/5/8" ]
Type contact : Channel02 "Fenster Treppenhaus West" [ ga="8/4/9" ]
Thing device RA3MDTUP "RA3 MDT Rolladenaktor UP Zimmer West-West" @ "KNX" [ address="1.1.62", fetch=false, pingInterval=600, readInterval=0 ]
Type rollershutter : Channel01 "Rolladen Zimmer West-West" [ upDown="3/1/9", stopMove="3/2/9", position="5.001:3/3/9+<3/5/9" ]
Type contact : Channel02 "Fenster Zimmer West-West" [ ga="8/4/10" ]
Thing device RA4MDTUP "RA4 MDT Rolladenaktor UP Zimmer West-Sued" @ "KNX" [ address="1.1.63", fetch=false, pingInterval=600, readInterval=0 ]
Type rollershutter : Channel01 "Rolladen Zimmer West-West" [ upDown="3/1/10", stopMove="3/2/10", position="5.001:3/3/10+<3/5/10" ]
Type contact : Channel02 "Fenster Zimmer West-West" [ ga="8/4/11" ]
Thing device RA5MDTUP "RA5 MDT Rolladenaktor UP Zimmer Ost-Sued" @ "KNX" [ address="1.1.64", fetch=false, pingInterval=600, readInterval=0 ]
Type rollershutter : Channel01 "Rolladen Zimmer West-West" [ upDown="3/1/12", stopMove="3/2/12", position="5.001:3/3/12+<3/5/12" ]
Type contact : Channel02 "Fenster Zimmer West-West" [ ga="<8/4/13" ]
Thing device BE1MDT "BE1 MDT Binäreingang Heizkeller" @ "KNX" [ address="1.1.70", fetch=false, pingInterval=600, readInterval=0 ]
Type contact : Channel01 "Balkontür" [ ga="1.019:<8/4/0" ]
Type contact : Channel02 "Fenster Wohnen Süd" [ ga="1.019:<8/4/1" ]
Type contact : Channel03 "Fenster Wohnen Ost" [ ga="1.019:<8/4/2" ]
Type contact : Channel04 "Fenster Küche Ost" [ ga="1.019:<8/4/3" ]
Thing device BE2MDTUP "BE2 MDT Binäreingang UP Haustür" @ "KNX" [ address="1.1.71", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Channel01 "Treppenhaus Licht" [ ga="1/1/18" ]
Type switch : Channel01T "Treppenhaus Licht Zeit" [ ga="1/0/18" ]
Type switch : Channel02 "Treppenhaus Licht an Haustür" [ ga="1/1/21" ]
Type switch : Channel02T "Aussenlicht Zeit" [ ga="1/0/22" ]
Type contact : Channel03 "Haustür Türkontakt" [ ga="1.019:<8/4/20" ]
Type contact : Channel04 "Garage Türkontakt" [ ga="1.019:<8/4/28" ]
Type contact : Channel05 "Garage Torkontakt" [ ga="1.019:<8/4/29" ]
Type switch : Channel06 "Garagenlicht" [ ga="1/1/23" ]
Thing device BE3MDTUP "BE3 MDT Binäreingang UP Waschküche" @ "KNX" [ address="1.1.72", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Channel01 "Licht Waschküche" [ ga="1/1/20" ]
Type switch : Channel01T "Kellertreppe Licht" [ ga="1/1/18" ]
Type switch : Channel01L "Szene" [ ga="0/1/13" ]
Type switch : Channel02 "Kellertreppe Licht" [ ga="1/1/19" ]
Type switch : Channel02T "Kellertreppe Licht Zeit" [ ga="1/0/19" ]
Thing device BE4MDTUP "BE4 MDT Binäreingang UP Bibliothek" @ "KNX" [ address="1.1.73", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Channel01 "Licht Gästebett" [ ga="1/1/28" ]
Type switch : Channel01L "Bibliothek Alles Aus" [ ga="2/0/4" ]
Thing device HA1MDTREG "HA1 MDT Heizungsaktor Heizkeller" @ "KNX" [ address="1.1.200", fetch=false, pingInterval=600, readInterval=0]
Type switch : Channel01 "Sommer/Winterumschaltung" [ ga="1.001:0/0/19" ]
Type switch : Channel02 "Heizung in Betrieb" [ ga="1.001:<12/0/1" ]
Type switch : Channel03 "Heizung Störung" [ ga="1.001:<12/0/2" ]
Type number : Channel04 "Heizung Temperatur Wohnzimmer" [ ga="9.001:<11/2/1" ]
Type number : Channel05 "Heizung Betriebsartenvorwahl" [ ga="5.005:12/6/0" ]
Type number : Channel06 "Heizung Sollwertverschiebung" [ ga="9.001:12/3/0" ]
Type number : Channel07 "Heizung aktueller Sollwert" [ ga="9.001:13/2/0" ]
Type number : Channel08 "Heizung Wohnzimmer Stellwert" [ ga="5.001:<13/1/0" ]
Type number : Channel09 "Heizung Wohnzimmer Betriebsart" [ ga="5.005:<13/6/0" ]
Thing device LO4MDT "LO4 MDT Wetterstation" @ "KNX" [ address="1.1.56", fetch=false, pingInterval=600, readInterval=0 ]
Type number : Channel01 "Helligkeit Ost" [ ga="9.004:<11/1/19" ]
Type switch : Channel02 "Schwellwert 1 Ost" [ ga="1.001:<4/0/1" ]
// Type switch : Channel03 "Schwellwert 2 Ost" [ ga="1.001:" ]
// Type switch : Channel04 "Sperrobjekt Schwellwert 1 Ost" [ ga="1.001:" ]
// Type switch : Channel05 "Sperrobjekt Schwellwert 2 Ost" [ ga="1.001:" ]
// Type number : Channel06 "Rolladenposition Ost senden" [ ga="5.001:" ]
// Type switch : Channel07 "Fassade Sperrobjekt Ost" [ ga="1.003:" ]
Type number : Channel08 "Helligkeit Süd" [ ga="9.004:<11/1/20" ]
Type switch : Channel09 "Schwellwert 1 Süd" [ ga="1.001:<4/0/2" ]
// Type switch : Channel10 "Schwellwert 2 Süd" [ ga="1.001:" ]
// Type switch : Channel11 "Sperrobjekt Schwellwert 1 Süd" [ ga="1.001:" ]
// Type switch : Channel12 "Sperrobjekt Schwellwert 2 Süd" [ ga="1.001:" ]
// Type number : Channel13 "Rolladenposition Süd senden" [ ga="5.001:" ]
// Type switch : Channel14 "Fassade Sperrobjekt Süd" [ ga="1.003:" ]
Type number : Channel15 "Helligkeit West" [ ga="9.004:<11/1/21" ]
Type switch : Channel16 "Schwellwert 1 West" [ ga="1.001:<4/0/3" ]
// Type switch : Channel17 "Schwellwert 2 West" [ ga="1.001:" ]
// Type switch : Channel18 "Sperrobjekt Schwellwert 1 West" [ ga="1.001:" ]
// Type switch : Channel19 "Sperrobjekt Schwellwert 2 West" [ ga="1.001:" ]
// Type number : Channel20 "Rolladenposition West senden" [ ga="5.001:" ]
// Type switch : Channel21 "Fassade Sperrobjekt West" [ ga="1.003:" ]
Type number : Channel22 "Dämmerung Helligkeit" [ ga="9.004:<11/1/23" ]
Type number : Channel23 "Windgeschwindigkeit" [ ga="9.005:<11/6/0" ]
Type number : Channel24 "Temperatur Aussen Ost" [ ga="9.004:<11/2/19" ]
Type switch : Channel25 "Nacht" [ ga="<0/0/12" ]
rollershutter.items
// Rolläden
// Group gRL "Rollläden Haus" <shutter> (All)
Group gRLEG "Rollläden EG" <shutter> (All)
Group gRLDG "Rollläden OG" <shutter> (All)
Group gBeschattung "Beschattung" <sun> (All)
Group gRLSammelgruppe "RL Sammelgruppen" <shutter> (All)
Group:Rollershutter:OR(0, 100) gRL "Rollläden [Position: %d %%]" <rollershutter> (All)
Group:Switch:OR(ON, OFF) gRLstati "Beschattungen [Aktiv: %d]" <rollershutter> (All)
// Rolladen EG
Rollershutter RL_Kueche_Ost "RL Küche EG [%d %%]" (gRLEG,gRL) [ "Lighting" ] { channel="knx:device:KNXRouter:RA1MDTREG:Channel01" }
Rollershutter RL_WoZi_Ost "RL Ost [%d %%]" (gRLEG,gRL) [ "Lighting" ] { channel="knx:device:KNXRouter:RA1MDTREG:Channel02" }
Rollershutter RL_WoZi_Sued "RL Süd [%d %%]" (gRLEG,gRL) [ "Lighting" ] { channel="knx:device:KNXRouter:RA1MDTREG:Channel03" }
Rollershutter RL_WoZi_Balkon "RL Balkon [%d %%]" (gRLEG,gRL) [ "Lighting" ] { channel="knx:device:KNXRouter:RA1MDTREG:Channel04" }
// Rolladen OG
Rollershutter RL_Treppenhaus "RL Treppenhaus [%d %%]" (gRLDG,gRL) [ "Lighting" ] { channel="knx:device:KNXRouter:RA2JUNGUP:Channel01" }
Rollershutter RL_Zimmer_West_West "RL Mediazimmer West [%d %%]" (gRLDG,gRL) [ "Lighting" ] { channel="knx:device:KNXRouter:RA3MDTUP:Channel01" }
Rollershutter RL_Zimmer_West_Sued "RL Mediazimmer Süd [%d %%]" (gRLDG,gRL) [ "Lighting" ] { channel="knx:device:KNXRouter:RA4MDTUP:Channel01" }
//Switch RL_Zimmer_West_Alle_Sperren "RL Mediazimmer sperren" (gRLDG,gRL) [ "Lighting" ] { channel="1.001:3/7/35" }
Rollershutter RL_Zimmer_Ost_Suedt "RL Gästezimmer Süd [%d %%]" (gRLDG,gRL) [ "Lighting" ] { channel="knx:device:KNXRouter:RA5MDTUP:Channel01" }
//Switch RL_Zimmer_Ost_Alle_Sperren "RL Gästezimmer sperren" (gRLDG,gRL) [ "Lighting" ] { channel="1.001:3/7/36" }
// Szenen für Rolläden
// Number Scene_RL "Szene Rolläden" (Szenen RL) [ "Lighting" ] { channel="1.022:0/1/1" }
// Beschattungen
Switch Beschattung_Haus "Beschattung Haus" (gBeschattung) { channel="1.001:4/0/0" }
Switch Beschattung_Ost "Beschattung Ost" (gBeschattung) { channel="1.001:4/0/1" }
Switch Beschattung_Sued "Beschattung Süd" (gBeschattung) { channel="1.001:4/0/2" }
Switch Beschattung_West "Beschattung West" (gBeschattung) { channel="1.001:4/0/3" }
Switch Beschattung_Automatik "Beschattung sperren" (gBeschattung) { channel="1.001:4/0/15" }
Switch Beschattung_Absolute_Pos_Sperren "Position Sperren" (gBeschattung) { channel="1.001:4/0/16" }
Switch Beschattung_Zimmer_West_Sperren "Beschattung Media sperren" (gBeschattung) { channel="1.001:3/0/39" }
Switch Beschattung_Zimmer_Ost_Sperren "Beschattung Gäste sperren" (gBeschattung) { channel="1.001:3/0/40" }
// Beschattung Stati
Switch Beschattung_Status_Kueche_Ost "Beschattung Küche Ost" (gRLstati) { channel="1.011:6/7/1" }
Switch Beschattung_Status_Wohnen_Ost "Beschattung Wohnen Ost" (gRLstati) { channel="1.011:6/7/2" }
Switch Beschattung_Status_Wohnen_Sued "Beschattung Wohnen Süd" (gRLstati) { channel="1.011:6/7/3" }
Switch Beschattung_Status_Wohnen_Balkon "Beschattung Balkon" (gRLstati) { channel="1.011:6/7/4" }
Switch Beschattung_Status_Schlafen "Beschattung Schlafen" (gRLstati) { channel="1.011:6/7/5" }
Switch Beschattung_Status_Zimmer_West_Sued "Beschattung Media Süd" (gRLstati) { channel="1.011:6/7/10" }
Switch Beschattung_Status_Zimmer_Ost_Sued "Beschattung Gäste Süd" (gRLstati) { channel="1.011:6/7/12" }
// Sammelgruppen
Rollershutter RL_Haus_Alles "RL Haus [%d %%]" (gRLSammelgruppe) { channel="1.008:3/1/16+5.001:3/5/3,3/2/16" }
Rollershutter RL_EG_Alles "RL Unten [%d %%]" (gRLSammelgruppe) { channel="1.008:3/1/33+5.001:3/5/3,3/2/33" }
Rollershutter RL_Zimmer_West_Alles "RL Mediazimmer [%d %%]" (gRLSammelgruppe) { channel="1.008:3/1/35+5.001:3/5/10,3/2/35" }
Rollershutter RL_Zimmer_Ost_Alles "RL Gäste [%d %%]" (gRLSammelgruppe) { channel="1.008:3/1/36+5.001:3/5/12,3/2/36" }
Rollershutter RL_OG_Alles "RL Oben [%d %%]" (gRLSammelgruppe) { channel="1.008:3/1/32+5.001:3/5/8,3/2/32" }
Rollershutter RL_Ost_Alles "RL Ost [%d %%]" (gRLSammelgruppe) { channel="1.008:3/1/17+5.001:3/5/3,3/2/17" }
Rollershutter RL_Sued_Alles "RL Süd [%d %%]" (gRLSammelgruppe) { channel="1.008:3/1/18+5.001:3/5/3,3/2/18" }
Rollershutter RL_West_Alles "RL West [%d %%]" (gRLSammelgruppe) { channel="1.008:3/1/19+5.001:3/5/8,3/2/19" }
