some days ago I changed the Thing definition for a Rollershutter as follows:
Thing device Jalou2 [
// device ID:
// Dieser Rolladenaktuator darf nicht mit korekter Hardwareadresse angegeben werden. OH fragt ihn sonst so oft ab, das er abstürzt!!!!!!!!!!!!!!!
address="1.1.5",
fetch=false,
pingInterval=600,
readInterval=0
Type rollershutter : Shutter_GF_WZ_South "Shutter_GF_WZ_South" [ upDown = "1/2/5+<1/2/5", stopMove = "1/2/4", position = "1/2/14<1/2/14" ]
Type rollershutter : Shutter_GF_WZ_West "Shutter_GF_WZ_West" [ upDown = "1/2/7+1/2/7", stopMove = "1/2/6", position = "1/2/16+<1/2/16" ]
Type rollershutter : Shutter_GF_WZ_North "Shutter_GF_WZ_North" [ upDown = "<1/2/9", stopMove = "1/2/8", position = "5.001:1/2/15+<1/2/15" ]
Before that, the 3 definitions resided in a “generic” Thing. I test it, was working. During the week I noticed, that the Rollershutter wasn’t working anymore. As soon as I reset the KNX-Bus it was working again. This was reproducable. Allways some minutes after the reset, the RS stoppt working, even when the GA was sent by a wallswitch (Gira). O.K., I thought the RS si out of order. I replaced it with an other RS, also Jung.
- one: 2204REGH
- one: 2204REG
The problem accoured also on the second one. I found, that when I change the Hardware-Adress to something else than the real adrress of the RS, there is no problem.
I can’t use the Busmonitor, only the GA-Monitor. I see, that OH starts to pull GAs from the RS, and the frequence increases by time.
I don’t know, if there is something wrong in my definitions. This accours only with these two actuators.
Also, the other KNX-devices appear as offline in PaperUI–>configuration–>things although some Harware-Adresses are given in the definition. Only the bridge is shown as online.
I use two IP/KNX-Gateways:
for OH: Eibmarkt KNX/IP-Interface
for ETS: CU-DIN IPRT
I don’t know if I’m doing something wrong, or if this is a bug of the KNX2 Binding. Maybe someone else can say something to this (funny) thing.
Thank,
Ingo
