KNX2 Temperature from KNX sensor not showing in BasicUI
Hello community,
I successfully migrate from KNX1 to KNX2 binding.
Rollershutters and lights are working perfectly and as well over BasicUI.
What I did not get to work is displaying the room temperature in BasicUI.
For any reason it´s displayed in PaperUI, but without °C (this is maybe a hint what is wrong).
It would be great if anybody could point me to my mistake.
Please find my configs here:
knx.items:
Number Temperatur_EG_Wohnzimmer     "Temperature [%.1f °C]"  { channel="knx:device:bridge:Temperatur_EG_Wohnzimmer" }
Number Temperatur_UG_Oelkeller      "Temperature [%.1f °C]"  { channel="knx:device:bridge:Temperatur_UG_Oelkeller" }
knx.things:
 Type number        : Temperatur_EG_Wohnzimmer     "Temperature [%.1f °C]"      [ ga="9.001:<1/1/0" ]
         Type number        : Temperatur_UG_Oelkeller      "Temperature [%.1f °C]"       [ ga="9.001:<1/1/1" ]
sitemap:
Text label="Temperatur und Heizung" icon="temperature" {
			Frame label="Temperatur und Heizung" {
				Text   item=Temperatur_EG_Wohnzimmer  icon="temperature"
				Text   item=Temperatur_UG_Oelkeller   icon="temperature"
Cheers Martin
Please post the complete knx.things-file.
I would use different names for the item and the channel.
For reference: KNX2: Ausgabe in Basic UI funktioniert nicht - KNX-User-Forum
I posted the (I’m pretty sure…) correct answer a few minutes ago…)
