OH2.4.0 Snapshot Build #1292
org.openhab.binding.knx binding Build # 2.4.0.201805280907 (KNXv2)
short version of the issue: When editing KNX.things with OH2 running and then saving the file, I get NPE: An error occurred while calling method 'ThingHandler.dispose()' on 'org.openhab.binding.knx.internal.handler.DeviceThingHandler@77cdb3b5': null
(One entry for every Thing defined)
With the following /etc/openhab2/things/KNX.things
Bridge knx:ip:GIRA2167 "GIRA KNX/IP Router" @ "KNX" [
type="ROUTER",
ipAddress="224.0.23.12",
portNumber=3671,
localIp="172.16.13.100",
readingPause=50,
responseTimeout=10,
readRetriesLimit=3,
autoReconnectPeriod=1,
localSourceAddr="1.2.200" ]
Thing device GW90741_1 "Switch Actuator 1" @ "KNX" [ address="1.1.1", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Ch_11 "Channel 1.1" [ ga="1/0/8+<1/2/8" ]
Type switch : Ch_12 "Channel 1.2" [ ga="1/0/9+<1/2/9" ]
Type switch : Ch_13 "Channel 1.3" [ ga="1/0/10+<1/2/12" ]
Type switch : Ch_14 "Channel 1.4" [ ga="1/0/11+<1/2/11" ]
Thing device GW90741_2 "Switch Actuator 2" @ "KNX" [ address="1.1.2", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Ch_21 "Channel 2.1" [ ga="1/0/6+<1/2/6" ]
Type switch : Ch_22 "Channel 2.2" [ ga="1/0/7+<1/2/7" ]
Type switch : Ch_23 "Channel 2.3" [ ga="1/0/1+<1/2/1" ]
Type switch : Ch_24 "Channel 2.4" [ ga="1/0/2+<1/2/2" ]
Thing device GW90741_3 "Switch Actuator 3" @ "KNX" [ address="1.1.3", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Ch_31 "Channel 3.1" [ ga="1/0/3+<1/2/3" ]
Type switch : Ch_32 "Channel 3.2" [ ga="1/0/4+<1/2/4" ]
Type switch : Ch_33 "Channel 3.3" [ ga="1/0/5+<1/2/5" ]
Type switch : Ch_34 "Channel 3.4" [ ga="1/0/14+<1/2/14" ]
Thing device GW90741_4 "Switch Actuator 4" @ "KNX" [ address="1.1.4", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Ch_41 "Channel 4.1" [ ga="1/0/12+<1/2/12" ]
Type switch : Ch_42 "Channel 4.2" [ ga="1/0/13+<1/2/13" ]
Type switch : Ch_43 "Channel 4.3" [ ga="1/0/14+<1/2/14" ]
Type switch : Ch_44 "Channel 4.4" [ ga="1/0/15+<1/2/15" ]
Thing device GW90741_5 "Switch Actuator 5" @ "KNX" [ address="1.1.5", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Ch_51 "Channel 5.1" [ ga="1/0/16+<1/2/16" ]
Type switch : Ch_52 "Channel 5.2" [ ga="1/0/17+<1/2/17" ]
Type switch : Ch_53 "Channel 5.3" [ ga="1/0/18+<1/2/18" ]
Type switch : Ch_54 "Channel 5.4" [ ga="1/0/19+<1/2/19" ]
Thing device GW90741_6 "Switch Actuator 6" @ "KNX" [ address="1.1.6", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Ch_61 "Channel 6.1" [ ga="1/1/0+<1/2/20" ]
Type switch : Ch_62 "Channel 6.2" [ ga="1/1/1+<1/2/21" ]
Type switch : Ch_63 "Channel 6.3" [ ga="1/1/2+<1/2/22" ]
Type switch : Ch_64 "Channel 6.4" [ ga="1/1/9+<1/2/29" ]
Thing device GW90741_7 "Switch Actuator 7" @ "KNX" [ address="1.1.7", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Ch_71 "Channel 7.1" [ ga="1/1/3+<1/2/23" ]
Type switch : Ch_72 "Channel 7.2" [ ga="1/1/4+<1/2/24" ]
Type switch : Ch_73 "Channel 7.3" [ ga="1/1/7+<1/2/27" ]
Type switch : Ch_74 "Channel 7.4" [ ga="1/1/8+<1/2/28" ]
Thing device GW90741_8 "Switch Actuator 8" @ "KNX" [ address="1.1.8", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Ch_81 "Channel 8.1" [ ga="1/1/10+<1/2/30" ]
Type switch : Ch_82 "Channel 8.2" [ ga="1/1/11+<1/2/31" ]
Type switch : Ch_83 "Channel 8.3" [ ga="1/1/12+<1/2/32" ]
Type switch : Ch_84 "Channel 8.4" [ ga="1/1/13+<1/2/33" ]
Thing device GW90741_9 "Switch Actuator 9" @ "KNX" [ address="1.1.9", fetch=false, pingInterval=600, readInterval=0 ]
Type switch : Ch_91 "Channel 9.1" [ ga="1/1/5+<1/2/25" ]
Type switch : Ch_92 "Channel 9.2" [ ga="1/1/6+<1/2/26" ]
Type switch : Ch_93 "Channel 9.3" [ ga="1/0/35+<1/2/35" ]
Type switch : Ch_94 "Channel 9.4" [ ga="1/0/36+<1/2/36" ]
Thing device GW90857_10 "Shutter Actuator 10" @ "KNX" [ address="1.1.10", fetch=false, pingInterval=600, readInterval=0 ]
Type rollershutter : Ch_101 "Channel 10.1" [ upDown="2/1/0", stopMove="2/1/1", position="2/3/10+<2/2/10" ]
Type rollershutter : Ch_102 "Channel 10.2" [ upDown="2/1/2", stopMove="2/1/3", position="2/3/12+<2/2/12" ]
Type rollershutter : Ch_103 "Channel 10.3" [ upDown="2/1/4", stopMove="2/1/5", position="2/3/14+<2/2/14" ]
Type rollershutter : Ch_104 "Channel 10.4" [ upDown="2/1/6", stopMove="2/1/7", position="2/3/16+<2/2/16" ]
Thing device GW90857_11 "Shutter Actuator 11" @ "KNX" [ address="1.1.11", fetch=false, pingInterval=600, readInterval=0 ]
Type rollershutter : Ch_111 "Channel 11.1" [ upDown="2/1/8", stopMove="2/1/9", position="2/3/18+<2/2/18" ]
Type rollershutter : Ch_112 "Channel 11.2" [ upDown="2/0/0", stopMove="2/0/1", position="2/3/0+<2/2/0" ]
Type rollershutter : Ch_113 "Channel 11.3" [ upDown="2/0/2", stopMove="2/0/3", position="2/3/2+<2/2/2" ]
Type rollershutter : Ch_114 "Channel 11.4" [ upDown="2/0/4", stopMove="2/0/5", position="2/3/4+<2/2/4" ]
Thing device GW90857_12 "Shutter Actuator 12" @ "KNX" [ address="1.1.12", fetch=false, pingInterval=600, readInterval=0 ]
Type rollershutter : Ch_121 "Channel 12.1" [ upDown="2/0/6", stopMove="2/0/7", position="2/3/6+<2/2/6" ]
Type rollershutter : Ch_122 "Channel 12.2" [ upDown="2/0/8", stopMove="2/0/9", position="2/3/8+<2/2/8" ]
Thing device PM30D01_C "3P Energy Meter Current" @ "KNX" [ address="1.1.32", fetch=false, pingInterval=600, readInterval=10 ]
Type number : Ch_CL1 "Channel CL1" [ ga="14.019:<3/1/1" ]
Type number : Ch_CL2 "Channel CL2" [ ga="14.019:<3/1/2" ]
Type number : Ch_CL3 "Channel CL3" [ ga="14.019:<3/1/3" ]
Thing device PM30D01_V "3P Energy Meter Voltage" @ "KNX" [ address="1.1.32", fetch=false, pingInterval=600, readInterval=300 ]
Type number : Ch_VL1N "Channel VL1N" [ ga="14.028:<3/2/1" ]
Type number : Ch_VL2N "Channel VL2N" [ ga="14.028:<3/2/2" ]
Type number : Ch_VL3N "Channel VL3N" [ ga="14.028:<3/2/3" ]
Type number : Ch_VL12 "Channel VL12" [ ga="14.028:<3/2/4" ]
Type number : Ch_VL23 "Channel VL23" [ ga="14.028:<3/2/5" ]
Type number : Ch_VL31 "Channel VL31" [ ga="14.028:<3/2/6" ]
Thing device PM30D01_P "3P Energy Meter Power" @ "KNX" [ address="1.1.32", fetch=false, pingInterval=600, readInterval=300 ]
Type number : Ch_ACPSum "Channel ACPSum" [ ga="14.056:<3/3/1" ]
Type number : Ch_ACPL1 "Channel ACPL1" [ ga="14.056:<3/3/2" ]
Type number : Ch_ACPL2 "Channel ACPL2" [ ga="14.056:<3/3/3" ]
Type number : Ch_ACPL3 "Channel ACPL3" [ ga="14.056:<3/3/4" ]
Type number : Ch_APPSum "Channel APPSum" [ ga="14.056:<3/3/5" ]
Type number : Ch_APPL1 "Channel APPL1" [ ga="14.056:<3/3/6" ]
Type number : Ch_APPL2 "Channel APPL2" [ ga="14.056:<3/3/7" ]
Type number : Ch_APPL3 "Channel APPL3" [ ga="14.056:<3/3/8" ]
Type number : Ch_RPSum "Channel RPSum" [ ga="14.056:<3/3/9" ]
Type number : Ch_RPL1 "Channel RPL1" [ ga="14.056:<3/3/10" ]
Type number : Ch_RPL2 "Channel RPL2" [ ga="14.056:<3/3/11" ]
Type number : Ch_RPL3 "Channel RPL3" [ ga="14.056:<3/3/12" ]
Type number : Ch_PFSum "Channel PFSum" [ ga="14.056:<3/3/13" ]
Type number : Ch_PFL1 "Channel PFL1" [ ga="14.056:<3/3/14" ]
Type number : Ch_PFL2 "Channel PFL2" [ ga="14.056:<3/3/15" ]
Type number : Ch_PFL3 "Channel PFL3" [ ga="14.056:<3/3/16" ]
Thing device PM30D01_E "3P Energy Meter Energy" @ "KNX" [ address="1.1.32", fetch=false, pingInterval=600, readInterval=300 ]
Type number : Ch_AEISum "Channel AEISum" [ ga="13.010:<3/4/1" ]
Type number : Ch_AEIL1 "Channel AEIL1" [ ga="13.010:<3/4/2" ]
Type number : Ch_AEIL2 "Channel AEIL2" [ ga="13.010:<3/4/3" ]
Type number : Ch_AEIL3 "Channel AEIL3" [ ga="13.010:<3/4/4" ]
Type number : Ch_AEESum "Channel AEESum" [ ga="13.010:<3/4/5" ]
Type number : Ch_AEEL1 "Channel AEEL1" [ ga="13.010:<3/4/6" ]
Type number : Ch_AEEL2 "Channel AEEL2" [ ga="13.010:<3/4/7" ]
Type number : Ch_AEEL3 "Channel AEEL3" [ ga="13.010:<3/4/8" ]
Type number : Ch_REISum "Channel REISum" [ ga="13.012:<3/4/9" ]
Type number : Ch_REIL1 "Channel REIL1" [ ga="13.012:<3/4/10" ]
Type number : Ch_REIL2 "Channel REIL2" [ ga="13.012:<3/4/11" ]
Type number : Ch_REIL3 "Channel REIL3" [ ga="13.012:<3/4/12" ]
Type number : Ch_REESum "Channel REESum" [ ga="13.012:<3/4/13" ]
Type number : Ch_REEL1 "Channel REEL1" [ ga="13.012:<3/4/14" ]
Type number : Ch_REEL2 "Channel REEL2" [ ga="13.012:<3/4/15" ]
Type number : Ch_REEL3 "Channel REEL3" [ ga="13.012:<3/4/16" ]
Thing device PM30D01_F "3P Energy Meter Frequency" @ "KNX" [ address="1.1.32", fetch=false, pingInterval=600, readInterval=300 ]
Type number : Ch_FR "Channel FR" [ ga="14.033:<3/5/1" ]
Everything works fine under normal operations.
When I edit the file (using vi) and change a parameter (e.g. readInterval
) and save it, the following errors pop up in openhab.log
2018-05-31 09:28:16.292 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.dispose()' on 'org.openhab.binding.knx.internal.handler.DeviceThingHandler@77cdb3b5': null
at org.openhab.binding.knx.handler.AbstractKNXThingHandler.detachFromClient(AbstractKNXThingHandler.java:208) [222:org.openhab.binding.knx:2.4.0.201805280907]
at org.openhab.binding.knx.handler.AbstractKNXThingHandler.dispose(AbstractKNXThingHandler.java:133) [222:org.openhab.binding.knx:2.4.0.201805280907]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [101:org.eclipse.smarthome.core:0.10.0.201805241348]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [101:org.eclipse.smarthome.core:0.10.0.201805241348]
2018-05-31 09:28:16.298 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while disposing handler of thing 'knx:device:GIRA2167:GW90741_1': null
2018-05-31 09:28:16.302 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.dispose()' on 'org.openhab.binding.knx.internal.handler.DeviceThingHandler@2e106e9f': null
2018-05-31 09:28:16.303 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while disposing handler of thing 'knx:device:GIRA2167:GW90741_2': null
2018-05-31 09:28:16.305 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.dispose()' on 'org.openhab.binding.knx.internal.handler.DeviceThingHandler@6a4f2e3a': null
2018-05-31 09:28:16.305 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while disposing handler of thing 'knx:device:GIRA2167:GW90741_3': null
2018-05-31 09:28:16.310 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.dispose()' on 'org.openhab.binding.knx.internal.handler.DeviceThingHandler@276989ed': null
2018-05-31 09:28:16.311 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while disposing handler of thing 'knx:device:GIRA2167:GW90741_4': null
2018-05-31 09:28:16.315 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.dispose()' on 'org.openhab.binding.knx.internal.handler.DeviceThingHandler@3d23d6ae': null
2018-05-31 09:28:16.316 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while disposing handler of thing 'knx:device:GIRA2167:GW90741_5': null
2018-05-31 09:28:16.320 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.dispose()' on 'org.openhab.binding.knx.internal.handler.DeviceThingHandler@10ea3303': null
2018-05-31 09:28:16.320 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while disposing handler of thing 'knx:device:GIRA2167:GW90741_6': null
2018-05-31 09:28:16.323 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.dispose()' on 'org.openhab.binding.knx.internal.handler.DeviceThingHandler@347f1da': null
2018-05-31 09:28:16.324 [ERROR] [ome.core.thing.internal.ThingManager] - Exception occurred while disposing handler of thing 'knx:device:GIRA2167:GW90741_7': null
[...] One entry for every Thing defined [...]
2018-05-31 09:28:16.395 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'KNX.things'
2018-05-31 09:28:17.586 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'KNX.things'
I am not sure if there is an error in my configs or this is a bug of the binding and deserves a github issue…
Anyone else seeing the same NPE when modifying the *.things
file on a live system to change some KNX parameters?
