Heya
I have wasted a good 4h this moring switching from a (near) perfectly working eibd setup to knxd.
I use a ABB USB interface connected to a Raspi3 with my OH installation.
Before switching to knxd i was using the command:
/usr/bin/eibd -d -D -S -T -i --pid-file=/var/run/eibd.pid usb:1:5:1:0:0
For knxd I used version 0.14.30 (the stable you get via apt install)
knxd --daemon=/var/log/knx.log --pid-file=/var/run/knx.pid --eibaddr=7.0.1 --client-addrs=7.0.2:3 --Name=knxd -D -T -S --listen-tcp=3671 -B log -b usb
Where the latter works as long as nothing is sent to the bus.
After sending to the usb - the log file shows:
knxd: Layer 0 [12:log/B.usb 135.606] Send L_Data low from 7.0.4 to 1/2/3 hops: 05 T_DATA_XXX_REQ A_GroupValue_Write (small) 00 knxd: Layer 0 [12:log/B.usb 135.907] State errored knxd: Layer 0 [12:log/B.usb 135.907] State stop knxd: F00000108: [14:B.usb] Send while buffer not empty knxd: Layer 0 [12:log/B.usb 135.907] State errored knxd: F00000105: [10:B.usb] Link down, terminating knxd: E00000035: [14:B.usb] SendError 40cee8 status 3
A search through github lead me to believe that it is to do with the timing that is set too low for USB devices.
It was supposedly fixed - But I could not see that. Maybe I missed setting some parameter? Or does knxd just not work with my ABB interface?
