Hi
How do i change so Kodi display current time and duration in hours, minutes and seconds instead of seconds in Basic UI?
The code is default “Current Time [%d %unit%]” and “Duration [%d %unit%]”
/Jerry
Hi
/Jerry
Yup me too, dont like the seconds for the time.
/Jerry
Thanks to @cweitkamp as I looked for something like this not long ago and it helped me today. Nevertheless I would like to further elaborate the topic by adding a few details:
First of all, install the Javascript Transformation via Paper UI.
kodi.items
Number:Time myKodi_currenttime "Current Time [JS(uptime.js):%s]" { channel="kodi:kodi:myKodi:currenttime" }
Number:Time myKodi_duration "Duration [JS(uptime.js):%s]" { channel="kodi:kodi:myKodi:duration" }
uptime.js
(put into transform
folder; all credits go to @KjetilA for his code; I have added the missing seconds to it and simplified it a bit )
(function(seconds) {
var retval = "";
var days = Math.floor(seconds / (24 * 60 * 60));
seconds = seconds % (24 * 60 * 60);
var hours = Math.floor(seconds / (60 * 60));
seconds = seconds % (60 * 60);
var minutes = Math.floor(seconds / 60);
seconds = seconds % 60;
if (days > 0) {
retval += days + " day";
if (days > 1) {
retval += "s";
retval += " ";
retval += hours + ":";
if (minutes < 10) {
retval += "0";
retval += minutes + ":";
if (seconds < 10) {
retval += "0";
retval += seconds;
return retval;
})(input);
I hope this helps. Of course there is a quite compact version of it as well (thanks to @Olymp; also without seconds).
Miba, there are some very long seconds on this .js, can it be redused to 2 digits?
/Jerry
I am not sure if I understand you right. The original value is the total number of seconds which will be converted to something like DD days HH:MM:SS
or HH:MM:SS
if it is below 1 day.
Nevermind, my bad. Works just i wanted it.
/Jerry
Great solution. Thank for posting your results. This will help until we will get a solution inside the framework.
You’re welcome. As mentioned it was your first reply that pushed me in the right direction.
It’s not working for me
In the panel I see NaN:NaN:NaN for both the Current time and Duration.
My items:
Number:Time KodiCurrentTime "Current Time [JS(uptime.js):%s]" { channel="kodi:kodi:KodiLivingRoom:currenttime" }
Number:Time KodiDuration "Duration [JS(uptime.js):%s]" { channel="kodi:kodi:KodiLivingRoom:duration" }
And I’ve copied the java code to uptime.js in the transformation folder;
I’m seeing this in the event.log when I start a movie in Kodi
2019-05-16 22:46:10.669 [vent.ItemStateChangedEvent] - KodiDuration changed from -1 s to 0 s
2019-05-16 22:46:19.653 [vent.ItemStateChangedEvent] - KodiCurrentTime changed from 0 s to 1848 s
2019-05-16 22:46:19.654 [vent.ItemStateChangedEvent] - KodiDuration changed from 0 s to 7338 s
2019-05-16 22:46:29.663 [vent.ItemStateChangedEvent] - KodiCurrentTime changed from 1848 s to 1858 s
2019-05-16 22:46:39.711 [vent.ItemStateChangedEvent] - KodiCurrentTime changed from 1858 s to 1868 s
What could I be missing?
