KODI IMDb Rating
HI everyone,
yesterday I just started with the KODI-Binding … Until now everything works instead of the IMDb-Rating.
In the log-file I see that it instantly switches from the correct state to 0.0 … and I don’t know what causes this …
Anyone else having the same problem?
item
  Number KODI_imdb_rating		"Wertung [%.1f]"	<imdb> {channel="kodi:kodi:kodi_wohnzimmer:rating"}`
sitemap
Text item=KODI_imdb_rating
log
2019-12-16 13:27:55.999 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 0.0 to 7.300000190734863
2019-12-16 13:27:56.000 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 7.300000190734863 to 0.0
Thanks in advance
No one?! :frowning:
what is the correct value ?
you mean the KODI_imd_rating is flipping out ?
Yes,
when I start a movie it instantly switches to the correct value and then again instantly from the correct value to 0.0 as you can see in the log file … and I don’t know why …
Hi all,
It looks like there is a small bug in the binding. The rating channel will be overridden by the value of the userrating. I will provide a fix for it.
Thanks for reporting :+1:.
Thank you very much! :slight_smile:
@cweitkamp
When do you think the fix will be implemented?
Cause I’ve just seen that it messes up my event.log
2020-01-06 21:10:26.618 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 0.0 to 7.300000190734863
2020-01-06 21:10:26.619 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 7.300000190734863 to 0.0
2020-01-06 21:10:36.747 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 0.0 to 7.300000190734863
2020-01-06 21:10:36.748 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 7.300000190734863 to 0.0
2020-01-06 21:10:46.853 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 0.0 to 7.300000190734863
2020-01-06 21:10:46.853 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 7.300000190734863 to 0.0
2020-01-06 21:10:56.964 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 0.0 to 7.300000190734863
2020-01-06 21:10:56.965 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 7.300000190734863 to 0.0
2020-01-06 21:11:07.085 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 0.0 to 7.300000190734863
2020-01-06 21:11:07.086 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 7.300000190734863 to 0.0
2020-01-06 21:11:17.205 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 0.0 to 7.300000190734863
2020-01-06 21:11:17.205 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 7.300000190734863 to 0.0
2020-01-06 21:11:27.299 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 0.0 to 7.300000190734863
2020-01-06 21:11:27.299 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 7.300000190734863 to 0.0
2020-01-06 21:11:37.401 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 0.0 to 7.300000190734863
2020-01-06 21:11:37.401 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 7.300000190734863 to 0.0
2020-01-06 21:11:47.508 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 0.0 to 7.300000190734863
2020-01-06 21:11:47.509 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 7.300000190734863 to 0.0
2020-01-06 21:11:57.626 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 0.0 to 7.300000190734863
2020-01-06 21:11:57.627 [vent.ItemStateChangedEvent] - KODI_imdb_rating changed from 7.300000190734863 to 0.0
The fix has been merged few days ago:
IIRC there will be a patch release this weekend (OH 2.5.1).
