Kodi install fails
I installed the kodi binding but can’t connect to my kodi. For debugging I trief to set the logger to debug but recieved an error in the console
log:set DEBUG org.openhab.binding.kodi
Error executing command: Unable to set level for logger
binding is active
338 │ Active │  80 │ 4.2.0.202405050350    │ org.openhab.binding.kodi
Do you have manually added a logger config to log4j2.xml?
In case yes, there is a known upstream issue in Karaf, see Change loglevel to Debug is not possible, Jinja Transformation, also for other Transformation Add-ons · Issue #3818 · openhab/openhab-core · GitHub for migitation.
added the logger via the opnehab console
I have the same issue with the tr064, yamaha binding as well
don’t have the issue with icalendar binding
