Confirmed. It does not work. I will open an issue in OH2.
Sending FASTWORWARD:
2017-07-04 21:07:25.605 [DEBUG] [i.internal.protocol.KodiClientSocket] - send message: {"jsonrpc":"2.0","id":103,"method":"Player.SetSpeed","params":{"playerid":1,"speed":"2"}}
2017-07-04 21:07:25.610 [DEBUG] [i.internal.protocol.KodiClientSocket] - Message received from server: {"error":{"code":-32602,"data":{"method":"Player.SetSpeed","stack":{"message":"Received value does not match any of the union type definitions","name":"speed","type":["string","integer"]}},"message":"Invalid params."},"id":103,"jsonrpc":"2.0"}
2017-07-04 21:07:25.612 [DEBUG] [i.internal.protocol.KodiClientSocket] - Response received from server: {"error":{"code":-32602,"data":{"method":"Player.SetSpeed","stack":{"message":"Received value does not match any of the union type definitions","name":"speed","type":["string","integer"]}},"message":"Invalid params."},"id":103,"jsonrpc":"2.0"}
2017-07-04 21:07:25.613 [DEBUG] [i.internal.protocol.KodiClientSocket] - callMethod returns {"error":{"code":-32602,"data":{"method":"Player.SetSpeed","stack":{"message":"Received value does not match any of the union type definitions","name":"speed","type":["string","integer"]}},"message":"Invalid params."},"id":103,"jsonrpc":"2.0"}
Sending REWIND:
2017-07-04 21:12:25.842 [DEBUG] [i.internal.protocol.KodiClientSocket] - send message: {"jsonrpc":"2.0","id":165,"method":"Player.SetSpeed","params":{"playerid":1,"speed":"-1"}}
2017-07-04 21:12:25.845 [DEBUG] [i.internal.protocol.KodiClientSocket] - Message received from server: {"error":{"code":-32602,"data":{"method":"Player.SetSpeed","stack":{"message":"Received value does not match any of the union type definitions","name":"speed","type":["string","integer"]}},"message":"Invalid params."},"id":165,"jsonrpc":"2.0"}
2017-07-04 21:12:25.846 [DEBUG] [i.internal.protocol.KodiClientSocket] - Response received from server: {"error":{"code":-32602,"data":{"method":"Player.SetSpeed","stack":{"message":"Received value does not match any of the union type definitions","name":"speed","type":["string","integer"]}},"message":"Invalid params."},"id":165,"jsonrpc":"2.0"}
2017-07-04 21:12:25.848 [DEBUG] [i.internal.protocol.KodiClientSocket] - callMethod returns {"error":{"code":-32602,"data":{"method":"Player.SetSpeed","stack":{"message":"Received value does not match any of the union type definitions","name":"speed","type":["string","integer"]}},"message":"Invalid params."},"id":165,"jsonrpc":"2.0"}
