There is a Kodi Plugin for OpenHAB, but was last updated in 2017.
I had installed it back then to play around with but never really used it, and did not reinstall it. In fact fogot about it until now…
If the OH plugin doesn’t work, you should be able to do it with MQTT or Node Red. I just did a quick Google search and there are lots of resources out there.
If you get it working, I imagine lots of people would be interested in a tutorial.
I’d think technically you will still want a setup with openHAB “controlling” Kodi.
Note OH can send commands yes but it can also retrieve states and act upon state changes (only).
So you would need the Kodi binding, configure OH to have an item to represent the Kodi play state, then trigger upon that item to change state in an OH rule to finally disable your phone etc in that rule.
I’ve just been pointed to this. I think there are use cases for both Kodi being used to control Openhab (as an interface ) and also Kodi being controlled by Openhab as a device.
I think this applies more generally for things like Smart TVs and also the tablet devices like Habpanelviewer.
