opened 10:03PM - 02 Mar 20 UTC
closed 07:21AM - 18 Jul 21 UTC
bug
Hello Kostal Zwave binding owner,
make a fresh openhabian installation, run upg…rade in openhabian menu, setup the basics in paper ui configuration/systems
then installed Kostal Binding.
go to inbox click + select Kostal Inverter Binding then I click KOSTAL PLENTICORE Plus 8.5 (no Battery) a Things pop-up come up and I can put in all details. Thing is added and I can see and select all channels and connect them to items. in Control I see all items with all values. Works great.
then I installed the zwave binding
binding = kostalinverter,zwave
after some minutes zwave binding is installed, check in logs. If I click Control in paper ui -> internal Server Error 500
under Things I see the Kostal inverter but no channels
as soon I removed zwave binding
Kostal thing and values show up in paper ui.
I posted here more details/infos
https://community.openhab.org/t/kostal-inverter-binding-interoperable-issue-thinks-not-working-uid-must-have-at-least-2-segments/90267
