channelTypeUID: knx:number
label: KWH_BoilerU
description: null
configuration:
ga: 13.013:<4/2/1
Knx is all cabled (no wireless) and i have an mdt ip router for connection openhab to knx.
the problem i have is that sometimes i dont know why and when but it appears that all values with KWH are with factor 10 in database. And after some minutes or sometimes days (maybe new starts of openhab between) the values were again correct read.
What is it in ETS diagnostic? May be the problem is not in OH.
At least you can make proxy item that will be intead of KWH_KWH_BoilerU and with help of rules do not send unreal values from itself to KWH_KWH_BoilerU.
So it seems more an knx device issue. I dont know how to solve it… Maybe a good idea to contact mdt
Do you think i could implement somehow a workaround? Maybe a rule like if value greater than 4000 then divide through 10. Because i see no new firmware for the mdt measurement-actor
Update: Ah, OK, now i know what you mean with proxy item. an item which receives value from knx, a rule which checks the value and device if nessecary and write it to the used-item. ok, now i have an idea how to do
As I understand, KWH_KWH_BoilerU is counter of consumed energy. So, may be better to compare with previously value. Like this if KWH_KWH_BoilerU_Current/KWH_KWH_BoilerU_Previously > 9 then KWH_KWH_BoilerU = KWH_KWH_BoilerU_Current/10. It will be universal method even when real value will be more then 4000.
But if this couter will reset, you must understand, that real values at restart can be 0, 1, 20… As you see 20 more than 1 in 20 times. And we can get wrong value in the chart.
You need one more condition when you compared new and previously value. For example
if (KWH_KWH_BoilerU_Previously>50)&&(KWH_KWH_BoilerU_Current/KWH_KWH_BoilerU_Previously > 9)
Hi Pavel,
thank you very much. I did an universal rule which is doing the job now. Im copying this here if someone has same problem:
//rule kwh_updated
//trigger from multiple [xxx]_orig items which filled from knx
//write correct value to [xxx] new items same name without_orig
var debug=1;
var ScriptExecution = Java.type("org.openhab.core.model.script.actions.ScriptExecution");
var ZonedDateTime = Java.type("java.time.ZonedDateTime");
//which kwh-item was changed?
var trigger="";
if (this.event !== undefined){
trigger= event.itemName;
if (trigger.contains("_orig")){
(debug==1)?logger.info ("getriggert"):null;
trigger2=trigger.replace('_orig', '');
var origstate=ir.getItem(trigger).getState();
var state=ir.getItem(trigger2).getState();
(debug==1)?logger.info(state-10):null;
(debug==1)?logger.info(origstate >(state+10)):null;
if (origstate<=10){//less than 10
(debug==1)?logger.info("value less 10"):null;
events.sendCommand(trigger2, origstate);
else if ((origstate <(state+10))&&(origstate>10)){//correct value
(debug==1)?logger.info("value correct"):null;
else if (((origstate/10) <(state+10))&&(origstate>10)){
state=origstate/10;//too big then correct it
(debug==1)?logger.info("value divided"):null;
events.sendCommand(trigger2, state);
else {
(debug==1)?logger.info("value not in limits"):null;
(debug==1)?logger.info(trigger+" from knx: "+origstate):null;
(debug==1)?logger.info(trigger2+" to item: "+state):null;
