La Crosse C84612 ws | TX60-U sensor Binding [4.0.0;5.9.0)
I made this binding to connect my La Crosse TX60-U sensors to openHAB. It also works with the La Crosse C84612 Weather stations (not yet tested). For the past 3 years I have been using the Python script weewx-interceptor modified to send the received sensor values into opehHAB via @Piotr_Bojko’s Webhook binding. However weewx-interceptor would only work with Python 2 and after upgrading my openHAB server recently, Python 2 was no longer available.
Using GitHub Copilot, I was able to quickly translate the Python code from weewx that handled low-level communication with the La Crosse GW1000U ERF gateway into Java and thus allow openHAB to natively support these devices.
Note that both the C84612 weather station and the TX60-U sensors are discontinued but can still be found on eBay in limited quantities. The TX60-U sensor can be found in a kit containing the GW1000U gateway under part number 926-25101-GP. Individual sensors seem to be very hard to find.
La Crosse Wireless Weather Station: Wind Rain Temp Model #C84612
La Crosse 926-25101-GP (TX60-U sensor and GW1000U gateway)
And now the standard README…
La Crosse Binding
This binding receives data from La Crosse C84612 weather stations or TX60-U temperature sensors via the hardwired Ethernet GW1000U ERF gateway.
Please note that this binding has not yet been tested with the La Crosse C84612 weather station.
The GW1000U must be configured to use the IP address and web server port of the openHAB server as its Proxyserver in order to use this binding.
The Gateway Advanced Setup (GAS) utility from La Crosse is used to change the gateway’s settings.
After this setting is changed in the gateway all data transmitted will be re-directed to openHAB.
Note that this also prevents any of these devices used with openHAB from using La Crosse’s online services (lacrossealertsmobile.com).
If you have any intention of using La Crosse’s alerts service, you should register your weather station with La Crosse before using this binding.
The routines used to allow communication with the gateway were adapted from weewx-interceptor and translated into Java using GitHub Copilot.
Most of the knowledge on how the GW1000U communicates was originally discussed here: https://www.wxforum.net/index.php?topic=14299.0
Discovery
Discovery is not supported. All things must be added manually.
The LacrosseInterceptorServlet can be accessed at http://$OPENHAB_IP:8080/request.breq to verify that it is active.
Any gateways that are configured to connect to openHAB will be displayed here along with the serial number that is needed for the Thing configuration.
The easiest way to obtain the serial number for the C84612 weather station is to register it with La Crosse Alerts and then view the serial number on their Device Settings page.
The serial number for a TX60-U sensor can be found on the sticker on the back of the sensor.
Once the things are configured properly, they will change to ONLINE status upon receipt of data from the gateway. Note however the status will never change to OFFLINE.
Supported Things
C84612 Weather Station
Thing type ID: weatherstation
Receives all measurements from the weather station and its outdoor sensors (Wind, Rain and Temp).
The weather station cannot be used along with TX60-U sensors on a single GW1000U gateway.
Using the weather station and TX60-U sensors requires at least 2 gateways.
Thing Configuration
Parameter Type Required Description
gatewaySn text yes The serial number (8 chars) of the GW1000U gateway hosting the weather station
stationSn text yes The serial number (16 chars) of the weather station
Channels
The C84612 Weather Station has the following channels (All channels are read-only):
Channel ID Label Item Type Description
temperatureIn Indoor Temperature Number:Temperature Measured indoor temperature (°C)
humidityIn Indoor Humidity Number:Dimensionless Measured indoor humidity (%)
temperatureOut Outdoor Temperature Number:Temperature Measured outdoor temperature (°C)
humidityOut Outdoor Humidity Number:Dimensionless Measured outdoor humidity (%)
windChill Wind Chill Number:Temperature Calculated wind chill temperature (°C)
rainTotal Total Rainfall Number:Length Total rainfall measured (cm)
rain Rainfall Number:Length Rainfall over the latest period (cm)
windDirection Wind Direction Number:Angle Current wind direction in degrees (1-360)
windSpeed Wind Speed Number:Speed Current wind speed (km/h)
gustDirection Gust Direction Number:Angle Current gust direction in degrees (1-360)
gustSpeed Gust Speed Number:Speed Current wind gust speed (km/h)
barometer Barometric Pressure Number:Pressure Current barometric pressure (mbar)
rfSignalStrength RF Signal Strength Number:Dimensionless RF signal strength as received at gateway (%)
status Status String Status of the weather station??
forecast Forecast String Weather forecast??
lastSeenDateTime Last Seen DateTime Last time data was received
TX60-U Sensor
Thing type ID: sensor
Supports up to 5 TX60-U sensors per gateway, each as a channel group.
The sensors display the temperature reading in °F only.
If the sensors were previously connected to the gateway, the sensor serial number of each sensor must be entered into the same number configuration parameter as currently registered in the gateway.
Thing Configuration
gatewaySn text yes The serial number (8 chars) of the GW1000U gateway hosting the sensors
sensor1sn text yes Serial number (16 chars) of the first TX60-U sensor
sensor2sn text no Serial number (16 chars) of the second TX60-U sensor (optional)
sensor3sn text no Serial number (16 chars) of the third TX60-U sensor (optional)
sensor4sn text no Serial number (16 chars) of the fourth TX60-U sensor (optional)
sensor5sn text no Serial number (16 chars) of the fifth TX60-U sensor (optional)
Channel Groups
Each sensor (1-5) provides the following channels (All channels are read-only):
temperature Temperature Number:Temperature Temperature measured at the sensor (°F)
temperatureProbe External Temperature Number:Temperature Temperature measured by the external probe (°F)
humidity Humidity Number:Dimensionless Humidity measured at the sensor (%)
heatIndex Heat Index Number:Temperature Calculated heat index (°F)
dewPoint Dew Point Number:Temperature Calculated dew point (°F)
batteryStatus Battery Status String Battery status (OK or Low)
lastSeenDateTime Last Seen DateTime DateTime Last time data was received from the sensor
Full Example
lacrosse.things Example
lacrosse:weatherstation:ws1 "Weather Station" [ gatewaySn="AABBCCDD", stationSn="1234567890ABCDEF" ]
lacrosse:sensor:mysensors "Temperature Sensors" [ gatewaySn="AABBCCDD", sensor1sn="1111222233334444", sensor2sn="5555666677778888" ]
lacrosse.items Example
Note that the expire directives will cause the state of the items to change to UNDEF if no updates are received for more than 45 minutes.
// Weather Station Items
Number:Temperature Weather_Indoor_Temp "Indoor Temperature [%.1f %unit%]" <temperature> { channel="lacrosse:weatherstation:ws1:temperatureIn", expire="45m" }
Number:Dimensionless Weather_Indoor_Humidity "Indoor Humidity [%d %%]" <humidity> { channel="lacrosse:weatherstation:ws1:humidityIn", expire="45m" }
Number:Temperature Weather_Outdoor_Temp "Outdoor Temperature [%.1f %unit%]" <temperature> { channel="lacrosse:weatherstation:ws1:temperatureOut", expire="45m" }
Number:Dimensionless Weather_Outdoor_Humidity "Outdoor Humidity [%d %%]" <humidity> { channel="lacrosse:weatherstation:ws1:humidityOut", expire="45m" }
Number:Temperature Weather_Wind_Chill "Wind Chill [%.1f %unit%]" { channel="lacrosse:weatherstation:ws1:windChill", expire="45m" }
Number:Length Weather_Rain_Total "Total Rainfall [%.1f %unit%]" { channel="lacrosse:weatherstation:ws1:rainTotal", expire="45m" }
Number:Length Weather_Rain "Rainfall [%.1f %unit%]" { channel="lacrosse:weatherstation:ws1:rain", expire="45m" }
Number:Angle Weather_Wind_Direction "Wind Direction [%d %unit%]" { channel="lacrosse:weatherstation:ws1:windDirection", expire="45m" }
Number:Speed Weather_Wind_Speed "Wind Speed [%.1f %unit%]" { channel="lacrosse:weatherstation:ws1:windSpeed", expire="45m" }
Number:Angle Weather_Gust_Direction "Gust Direction [%d %unit%]" { channel="lacrosse:weatherstation:ws1:gustDirection", expire="45m" }
Number:Speed Weather_Gust_Speed "Gust Speed [%.1f %unit%]" { channel="lacrosse:weatherstation:ws1:gustSpeed", expire="45m" }
Number:Pressure Weather_Barometer "Barometric Pressure [%.1f %unit%]" { channel="lacrosse:weatherstation:ws1:barometer", expire="45m" }
Number:Dimensionless Weather_RF_Signal "RF Signal Strength [%d %%]" { channel="lacrosse:weatherstation:ws1:rfSignalStrength", expire="45m" }
String Weather_Status "Status [%s]" { channel="lacrosse:weatherstation:ws1:status", expire="45m" }
String Weather_Forecast "Forecast [%s]" { channel="lacrosse:weatherstation:ws1:forecast", expire="45m" }
DateTime Weather_Last_Seen "Last Seen [%1$tA, %1$tm-%1$td-%1$tY %1$tl:%1$tM %1$tp]" { channel="lacrosse:weatherstation:ws1:lastSeenDateTime" }
// TX60-U Sensor 1 Items
Number:Temperature TX60U1_Temperature "Sensor 1 Temperature [%.1f %unit%]" <temperature> { channel="lacrosse:sensor:mysensors:sensor1#temperature", expire="45m" }
Number:Temperature TX60U1_External_Temperature "Sensor 1 External Temp [%.1f %unit%]" <temperature> { channel="lacrosse:sensor:mysensors:sensor1#temperatureProbe", expire="45m" }
Number:Dimensionless TX60U1_Humidity "Sensor 1 Humidity [%d %%]" <humidity> { channel="lacrosse:sensor:mysensors:sensor1#humidity", expire="45m" }
Number:Temperature TX60U1_Heat_Index "Sensor 1 Heat Index [%.1f %unit%]" { channel="lacrosse:sensor:mysensors:sensor1#heatIndex", expire="45m" }
Number:Temperature TX60U1_Dew_Point "Sensor 1 Dew Point [%.1f %unit%]" { channel="lacrosse:sensor:mysensors:sensor1#dewPoint", expire="45m" }
Number:Dimensionless TX60U1_RF_Signal "Sensor 1 RF Signal [%d %%]" { channel="lacrosse:sensor:mysensors:sensor1#rfSignalStrength", expire="45m" }
String TX60U1_Battery_Status "Sensor 1 Battery [%s]" { channel="lacrosse:sensor:mysensors:sensor1#batteryStatus" }
DateTime TX60U1_Last_Seen "Sensor 1 Last Seen [%1$tA, %1$tm-%1$td-%1$tY %1$tl:%1$tM %1$tp]" { channel="lacrosse:sensor:mysensors:sensor1#lastSeenDateTime" }
// TX60-U Sensor 2 Items
Number:Temperature TX60U2_Temperature "Sensor 2 Temperature [%.1f %unit%]" <temperature> { channel="lacrosse:sensor:mysensors:sensor2#temperature", expire="45m" }
Number:Temperature TX60U2_External_Temperature "Sensor 2 External Temp [%.1f %unit%]" <temperature> { channel="lacrosse:sensor:mysensors:sensor2#temperatureProbe", expire="45m" }
Number:Dimensionless TX60U2_Humidity "Sensor 2 Humidity [%d %%]" <humidity> { channel="lacrosse:sensor:mysensors:sensor2#humidity", expire="45m" }
Number:Temperature TX60U2_Heat_Index "Sensor 2 Heat Index [%.1f %unit%]" { channel="lacrosse:sensor:mysensors:sensor2#heatIndex", expire="45m" }
Number:Temperature TX60U2_Dew_Point "Sensor 2 Dew Point [%.1f %unit%]" { channel="lacrosse:sensor:mysensors:sensor2#dewPoint", expire="45m" }
Number:Dimensionless TX60U2_RF_Signal "Sensor 2 RF Signal [%d %%]" { channel="lacrosse:sensor:mysensors:sensor2#rfSignalStrength", expire="45m" }
String TX60U2_Battery_Status "Sensor 2 Battery [%s]" { channel="lacrosse:sensor:mysensors:sensor2#batteryStatus" }
DateTime TX60U2_Last_Seen "Sensor 2 Last Seen [%1$tA, %1$tm-%1$td-%1$tY %1$tl:%1$tM %1$tp]" { channel="lacrosse:sensor:mysensors:sensor2#lastSeenDateTime" }
// Add more TX60-U sensor items as needed
lacrosse.sitemap Example
sitemap lacrosse label="La Crosse" {
  Frame label="Weather Station" {
    Text item=Weather_Indoor_Temp icon="temperature"
    Text item=Weather_Indoor_Humidity icon="humidity"
    Text item=Weather_Outdoor_Temp icon="temperature"
    Text item=Weather_Outdoor_Humidity icon="humidity"
    Text item=Weather_Wind_Chill icon="temperature_cold"
    Text item=Weather_Rain_Total icon="rain"
    Text item=Weather_Rain icon="rain"
    Text item=Weather_Wind_Direction icon="wind"
    Text item=Weather_Wind_Speed icon="wind"
    Text item=Weather_Gust_Direction icon="wind"
    Text item=Weather_Gust_Speed icon="wind"
    Text item=Weather_Barometer icon="pressure"
    Text item=Weather_RF_Signal icon="qualityofservice"
    Text item=Weather_Status
    Text item=Weather_Forecast
    Text item=Weather_Last_Seen icon="time"
  Frame label="TX60-U Sensor 1" {
    Text item=TX60U1_Temperature icon="temperature"
    Text item=TX60U1_External_Temperature icon="temperature"
    Text item=TX60U1_Humidity icon="humidity"
    Text item=TX60U1_Heat_Index icon="temperature_hot"
    Text item=TX60U1_Dew_Point icon="temperature"
    Text item=TX60U1_RF_Signal icon="qualityofservice"
    Text item=TX60U1_Battery_Status icon="batterylevel"
    Text item=TX60U1_Last_Seen icon="time"
  Frame label="TX60-U Sensor 2" {
    Text item=TX60U2_Temperature icon="temperature"
    Text item=TX60U2_External_Temperature icon="temperature"
    Text item=TX60U2_Humidity icon="humidity"
    Text item=TX60U2_Heat_Index icon="temperature_hot"
    Text item=TX60U2_Dew_Point icon="temperature"
    Text item=TX60U2_RF_Signal icon="qualityofservice"
    Text item=TX60U2_Battery_Status icon="batterylevel"
    Text item=TX60U2_Last_Seen icon="time"
  // Add more TX60-U sensor frames as needed
Changelog
Version 0.1
  • Initial Add-on Marketplace release
Resources
https://github.com/mlobstein/openhab-addons/releases/download/v0.1/org.openhab.binding.lacrosse-4.3.0-SNAPSHOT.jar
Source code: openhab-addons/bundles/org.openhab.binding.lacrosse at lacrosse · mlobstein/openhab-addons · GitHub
Here is a screenshot showing how to configure the GW1000U ERF gateway so that it sends all of its data to openHAB:
The installer for Gateway Advanced Setup utility gatewayadmininstall.exe
can be found on the La Crosse support page: Downloads - La Crosse Alerts Mobile
