I configured some basic items after things definition via Paper UI, here is my items file:
Group External // information not in control of the home, e.g., Weather, Sunset
DateTime DateT "Today is [%1$tA, %1$td.%1$tm.%1$tY %1$tT]" (External) { channel="ntp:ntp:local:dateTime" }
* Current Weather taken from Yahoo
Number Temperature "Outside Temp. [%.1f °C]" (External) { channel = "yahooweather:weather:157a63ccb65:temperature" }
Number Humidity "Humidity [%.1f %%]" (External) { channel = "yahooweather:weather:157a63ccb65:humidity" }
Number Pressure "Pressure [%.1f hPa]" (External) { channel = "yahooweather:weather:157a63ccb65:pressure" }
These ones I used in a sitemap definition as follows
sitemap schopen label="My SchopenHome" {
Frame label="Info" {
Text item=DateT icon="calendar"
Text item=Temperature icon="temperature"
Text item=Humidity icon="rain"
What I do not understand is that the labels defined in the items file seems to be completely ignored, instead the items are labeled with their name:
Do I miss some configuration settings? Or is it necessary to have the labels defined in sitemaps file? But if the latter is true, what is the reasoning behind the labels in items file?
