Hi all,
first of all: thanks for the amazing work, that the community does. I am using openHAB since about 6 months controlling my lights and rollershutters (by LCN / Issendorff). Recently, I introduced Alexa and got a rule to manage the up/down/stop commands. The item looks as follows:
Rollershutter EGArbeitszimmerGross "Arbeitszimmer Gross" <rollershutter> (Huette, Strasse, EGAZimmer)["Switchable"] {lcn="[UP:lcnzinow:RELAYS.0.14.----11--], [DOWN:lcnzinow:RELAYS.0.14.----10--], [STOP:lcnzinow:RELAYS.0.14.----00--]"}
The corresponsing rule looks like this:
rule "EGAZG"
Item EGArbeitszimmerGross received command
logInfo("EGAZG","Rule triggered with {}",receivedCommand)
switch(receivedCommand) {
case 100 : {
EGArbeitszimmerGross.sendCommand(UP)
logInfo("EGAZ","Rollo hoch")
case 49 : {
EGArbeitszimmerGross.sendCommand(STOP)
logInfo("EGAZ","Rollo STOP")
case 0 : {
EGArbeitszimmerGross.sendCommand(DOWN)
logInfo("EGAZ","Rollo runter")
and it works fine. As I have quite a few rollershutters I looked for a way to write a routine, that I could pass both the item name as well as the command to avoid duplicating code. I found @rlkoshak contributions on the concept of lambdas and converted my rule into the following:
import org.eclipse.xtext.xbase.lib.Functions
val Functions$Function2<GenericItem, String, Boolean> rollladenHandler = [
GenericItem rollladen, String Wert |
logInfo("Lambda","Lambda: " + rollladen.name.toString + " " + Wert)
switch(Integer.parseInt(Wert)) {
case 100 : {
rollladen.sendCommand(DOWN)
logInfo("Lambda",rollladen.name.toString + " down")
case 49 : {
rollladen.sendCommand(STOP)
logInfo("Lambda",rollladen.name.toString + " stop")
case 0 : {
rollladen.sendCommand(UP)
logInfo("Lambda",rollladen.name.toString + " up")
true
rule "EGAZG"
logInfo("EGAZG","Rule EGAZG triggerd with ",receivedCommand)
rollladenHandler.apply(EGArbeitszimmerGross,EGArbeitszimmerGross.state.toString)
The result is, that it looks as if the rule performs the task and then triggers itself.
10:16:39.402 [INFO ] [eclipse.smarthome.model.script.EGAZG] - Rule EGAZG triggerd with UP
10:16:39.406 [INFO ] [clipse.smarthome.model.script.Lambda] - Lambda: EGArbeitszimmerGross 0
10:16:39.409 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'EGArbeitszimmerGross' received command UP
10:16:39.410 [INFO ] [clipse.smarthome.model.script.Lambda] - EGArbeitszimmerGross up
10:16:39.414 [INFO ] [eclipse.smarthome.model.script.EGAZG] - Rule EGAZG triggerd with UP
10:16:39.418 [INFO ] [clipse.smarthome.model.script.Lambda] - Lambda: EGArbeitszimmerGross 0
10:16:39.421 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'EGArbeitszimmerGross' received command UP
10:16:39.422 [INFO ] [clipse.smarthome.model.script.Lambda] - EGArbeitszimmerGross up
10:16:39.426 [INFO ] [eclipse.smarthome.model.script.EGAZG] - Rule EGAZG triggerd with UP
10:16:39.429 [INFO ] [clipse.smarthome.model.script.Lambda] - Lambda: EGArbeitszimmerGross 0
10:16:39.432 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'EGArbeitszimmerGross' received command UP
10:16:39.433 [INFO ] [clipse.smarthome.model.script.Lambda] - EGArbeitszimmerGross up
10:16:39.436 [INFO ] [eclipse.smarthome.model.script.EGAZG] - Rule EGAZG triggerd with UP
10:16:39.440 [INFO ] [clipse.smarthome.model.script.Lambda] - Lambda: EGArbeitszimmerGross 0
10:16:39.442 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'EGArbeitszimmerGross' received command UP
10:16:39.443 [INFO ] [clipse.smarthome.model.script.Lambda] - EGArbeitszimmerGross up
10:16:39.447 [INFO ] [eclipse.smarthome.model.script.EGAZG] - Rule EGAZG triggerd with UP
10:16:39.451 [INFO ] [clipse.smarthome.model.script.Lambda] - Lambda: EGArbeitszimmerGross 0
10:16:39.453 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'EGArbeitszimmerGross' received command UP
I read about locks and hatches, but have no clue, what I got wrong when introducing the lambda. Any clue?
Best regards
Rainer
