I have a lambda “SendNotification” passed as parameter, the call to this lambda are in comment now because it doesn’t work.
// notification to push bullet, email and optionnally to imperihome
var org.eclipse.xtext.xbase.lib.Procedures$Procedure3<String, String, boolean> sendNotification = [
String title,
String subject,
boolean isVocal |
logDebug("sendNotification", title)
// send to pushbullet
executeCommandLine("curl@@-k@@-H@@Access-Token: xxx@@-XPOST@@https://api.pushbullet.com/v2/pushes@@-H@@Content-Type: application/json@@--data-binary@@{\"type\": \"note\", \"title\": \"" + title + "\", \"body\": \"" + subject + "\"}@@")
// send email
sendMail("xxxxx@gmail.com", title, subject)
// send text to speech to imperihome
if(isVocal){
imperiHabSay(subject)
var org.eclipse.xtext.xbase.lib.Functions$Function5 runningMachineAlert = [
org.openhab.core.library.items.NumberItem machineItem,
java.util.Map<String, org.openhab.model.script.actions.Timer> checkRunningMachineTimers,
java.util.Map<String, int> checkRunningMachineIsSleepings,
java.util.Map<String, org.eclipse.xtext.xbase.lib.Procedures$Procedure1<Object>> runningMachineFuncs,
org.eclipse.xtext.xbase.lib.Procedures$Procedure3<String, String, boolean> sendNotification |
if(runningMachineFuncs.get(machineItem.name) == null){
var org.eclipse.xtext.xbase.lib.Procedures$Procedure1<Object> machineFuncGlobal = [ Object machineFunc |
var org.eclipse.xtext.xbase.lib.Procedures$Procedure1 updateState = [
String message |
if(machineItem.name == "Conso_WashingMachine"){
postUpdate(WashingState, message)
} else {
if(machineItem.name == "Conso_Backup"){
postUpdate(DryerState, message)
if(machineItem.state < 10){
logDebug("Machine Alert", "Washing machine is consumming low...")
if(checkRunningMachineIsSleepings.get(machineItem.name) < 60){
// check 60 so it 10 min to receive 2 updates from server
//updateState.apply("Consomme peu...")
postUpdate(WashingState, "Consomme peu...")
} else {
postUpdate(DryerState, "Consomme peu...")
logDebug("Machine Alert", "Check low consumption is " + checkRunningMachineIsSleepings.get(machineItem.name))
checkRunningMachineIsSleepings.put(machineItem.name, checkRunningMachineIsSleepings.get(machineItem.name) + 1)
checkRunningMachineTimers.put(machineItem.name, createTimerWithArgument(now.plusSeconds(10), machineFunc, machineFunc as org.eclipse.xtext.xbase.lib.Procedures$Procedure1<Object>))
else {
logDebug("Washing Machine Alert", "Washing machine is finished")
checkRunningMachineIsSleepings.put(machineItem.name, 0);
if(checkRunningMachineTimers.get(machineItem.name) !=null){
checkRunningMachineTimers.get(machineItem.name).cancel();
checkRunningMachineTimers.remove(machineItem.name);
//updateState.apply("Fini, vider la machine")
postUpdate(WashingState, "Fini, vider la machine")
} else {
postUpdate(DryerState, "Fini, vider la machine")
executeCommandLine("curl@@-k@@-H@@Access-Token: cz8nT4eoI4Eb4MWlSslsjcpK7yav4ySu@@-XPOST@@https://api.pushbullet.com/v2/pushes@@-H@@Content-Type: application/json@@--data-binary@@{\"type\": \"note\", \"title\": \"" + "Openhab" + "\", \"body\": \"" + "La machine Ă laver Ă fini" + "\"}@@")
imperiHabSay("La machine Ă laver Ă fini")
//sendNotification.apply("La machine a laver a fini", "", true)
} else {
executeCommandLine("curl@@-k@@-H@@Access-Token: cz8nT4eoI4Eb4MWlSslsjcpK7yav4ySu@@-XPOST@@https://api.pushbullet.com/v2/pushes@@-H@@Content-Type: application/json@@--data-binary@@{\"type\": \"note\", \"title\": \"" + "Openhab" + "\", \"body\": \"" + "Le sèche linge à fini" + "\"}@@")
imperiHabSay("Le sèche linge à fini")
//sendNotification.apply("Le seche linge a fini", "", true)
} else {
//sendNotification.apply("Une machine a fini de tourner", "", true)
else {
logDebug("Machine Alert", "Machine is running...")
//updateState.apply("Tourne")
postUpdate(WashingState, "Tourne")
} else {
postUpdate(DryerState, "Tourne")
runningMachineFuncs.put(machineItem.name, machineFuncGlobal)
if(machineItem.state > 10 && checkRunningMachineTimers.get(machineItem.name) == null){
logDebug("Machine Alert", "Machine starting detected")
imperiHabSay("La machine à laver ou le sèche linge à commencé")
// machine is consumming and timer is not started so machine is just starting
var timerMachine = createTimerWithArgument(now.plusSeconds(10),runningMachineFuncs.get(machineItem.name), runningMachineFuncs.get(machineItem.name))
checkRunningMachineTimers.put(machineItem.name, timerMachine)
//postUpdate(WashingState, "Tourne")
