Hello together,
I must say I am pretty happy with my current setup, except the stability issues. I need to restart the system every week, because some rules stops working. Seems to be core or java bugs?
This is one of the bugs, which appears sometimes.
- Platform information:
- Hardware: Rpi4, 4GB
- OS: openHABian 3.1
2021-11-23 11:38:26.956 [ERROR] [t.ide.server.concurrent.WriteRequest] - Error during request:
java.util.concurrent.CompletionException: java.lang.RuntimeException: Cannot create a resource for 'java:/Objects/org.openhab.core.items.GenericItem'; a registered resource factory is needed
at java.util.concurrent.CompletableFuture.encodeThrowable(CompletableFuture.java:331) ~[?:?]
at java.util.concurrent.CompletableFuture.andTree(CompletableFuture.java:1452) ~[?:?]
at java.util.concurrent.CompletableFuture.andTree(CompletableFuture.java:1442) ~[?:?]
at java.util.concurrent.CompletableFuture.andTree(CompletableFuture.java:1444) ~[?:?]
at java.util.concurrent.CompletableFuture.allOf(CompletableFuture.java:2337) ~[?:?]
at org.eclipse.xtext.ide.server.concurrent.RequestManager.cancel(RequestManager.java:114) ~[?:?]
at org.eclipse.xtext.ide.server.concurrent.RequestManager.runWrite(RequestManager.java:80) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.runBuildable(LanguageServerImpl.java:458) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.didChange(LanguageServerImpl.java:398) ~[?:?]
at jdk.internal.reflect.GeneratedMethodAccessor196.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.services.GenericEndpoint.lambda$null$0(GenericEndpoint.java:65) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.services.GenericEndpoint.notify(GenericEndpoint.java:152) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.RemoteEndpoint.handleNotification(RemoteEndpoint.java:220) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.RemoteEndpoint.consume(RemoteEndpoint.java:187) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.json.StreamMessageProducer.handleMessage(StreamMessageProducer.java:194) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.json.StreamMessageProducer.listen(StreamMessageProducer.java:94) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.json.ConcurrentMessageProcessor.run(ConcurrentMessageProcessor.java:113) ~[?:?]
Caused by: java.lang.RuntimeException: Cannot create a resource for 'java:/Objects/org.openhab.core.items.GenericItem'; a registered resource factory is needed
at org.eclipse.xtext.resource.XtextResourceSet.getResource(XtextResourceSet.java:263) ~[?:?]
at org.eclipse.xtext.ide.server.ProjectManager.getResource(ProjectManager.java:169) ~[?:?]
at org.eclipse.xtext.ide.server.WorkspaceManager.doRead(WorkspaceManager.java:436) ~[?:?]
at org.eclipse.xtext.ide.server.findReferences.WorkspaceResourceAccess.readOnly(WorkspaceResourceAccess.java:36) ~[?:?]
at org.eclipse.xtext.ide.server.symbol.DocumentSymbolService.doRead(DocumentSymbolService.java:332) ~[?:?]
at org.eclipse.xtext.ide.server.symbol.DocumentSymbolService.getDefinitions(DocumentSymbolService.java:112) ~[?:?]
at org.eclipse.xtext.ide.server.symbol.DocumentSymbolService.getDefinitions(DocumentSymbolService.java:99) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$definition$24(LanguageServerImpl.java:608) ~[?:?]
at org.eclipse.xtext.ide.server.WorkspaceManager.doRead(WorkspaceManager.java:438) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.definition(LanguageServerImpl.java:607) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.definition(LanguageServerImpl.java:595) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$definition$23(LanguageServerImpl.java:586) ~[?:?]
at org.eclipse.xtext.ide.server.concurrent.ReadRequest.lambda$doRun$0(ReadRequest.java:66) ~[?:?]
... 5 more
