Just apt-get update to the latest snapshot and unfortunately it wiped out all my things and items. Just a heads up and another call for someway to backup / restore the underlying database. since this isn’t the first time this has happened to me (previous were when I was doing manual updates)
Is this the first time you’ve upgraded for a few days? If so, it’s probably due to the storage system change -:
I ran into the same problem, understand I have to re-create all things. I was able to add my Razberry z-wave controller again, but it shows up as offline and I get this in the logs:
2016-12-03 22:07:31.117 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-12-03 22:07:36.122 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-12-03 22:07:41.124 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-12-03 22:07:46.127 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Too many retries. Discarding message: Message: class=GetVersion[0x15], type=Request[0x00], priority=High, dest=255, callback=0, payload=
2016-12-03 22:07:51.130 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-12-03 22:07:56.133 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-12-03 22:08:01.135 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-12-03 22:08:06.139 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Too many retries. Discarding message: Message: class=MemoryGetId[0x20], type=Request[0x00], priority=High, dest=255, callback=0, payload=
2016-12-03 22:08:11.141 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-12-03 22:08:16.144 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-12-03 22:08:21.147 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-12-03 22:08:26.150 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Too many retries. Discarding message: Message: class=SerialApiGetCapabilities[0x07], type=Request[0x00], priority=High, dest=255, callback=0, payload=
2016-12-03 22:08:31.153 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-12-03 22:08:36.156 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-12-03 22:08:41.159 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-12-03 22:08:46.162 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Too many retries. Discarding message: Message: class=SerialApiSetTimeouts[0x06], type=Request[0x00], priority=High, dest=255, callback=0, payload=96 0F
2016-12-03 22:08:51.165 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-12-03 22:08:56.168 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-12-03 22:09:01.171 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-12-03 22:09:06.174 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Too many retries. Discarding message: Message: class=GetSucNodeId[0x56], type=Request[0x00], priority=High, dest=255, callback=0, payload=
Any idea ?
I had to re-add my zwave controller and restart everything
That’s also what I did, but I keep getting the errors in the logfile and the controller shows up as offline in the GUIs
The log doesn’t really help with debugging - I’d suggest to make sure that you’ve configured the controller properly (eg serial port) and if so put logging into debug to see what it shows…
Connection thru the serial port looks OK. This is the log after a re-start with DEBUG logging:
2016-12-03 22:28:51.429 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Initializing ZWave serial controller.
2016-12-03 22:28:51.431 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Initializing ZWave Controller.
2016-12-03 22:28:51.437 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyAMA0'
2016-12-03 22:28:51.506 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Starting receive thread
2016-12-03 22:28:51.511 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2016-12-03 22:28:51.511 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Starting ZWave thread: Receive
2016-12-03 22:28:51.512 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Initialising ZWave controller
2016-12-03 22:28:51.537 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
2016-12-03 22:28:51.564 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2016-12-03 22:28:51.565 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2016-12-03 22:28:51.571 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Starting ZWave thread: Send
2016-12-03 22:28:51.574 [DEBUG] [ve.internal.protocol.ZWaveController] - Starting ZWave thread: Input
2016-12-03 22:28:51.579 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - Activating ZWave discovery service for zwave:serial_zstick:2333d188
2016-12-03 22:28:51.581 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=299, service.bundleid=177, service.scope=singleton} - org.openhab.binding.zwave
2016-12-03 22:28:51.822 [INFO ] [clipse.smarthome.model.script.garage] - system startup
2016-12-03 22:28:52.927 [INFO ] [pse.smarthome.model.script.alarmpies] - system startup
2016-12-03 22:28:54.566 [DEBUG] [.ZWaveController$InitializeDelayTask] - Initialising network
2016-12-03 22:28:54.582 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2016-12-03 22:28:54.584 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 0. Queue={}
2016-12-03 22:28:54.585 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 15 E9
2016-12-03 22:28:54.586 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 15 E9
2016-12-03 22:28:54.589 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2016-12-03 22:28:54.593 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 2. Queue={}
2016-12-03 22:28:54.597 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 3. Queue={}
2016-12-03 22:28:54.601 [DEBUG] [rialmessage.GetSucNodeIdMessageClass] - Get SUC NodeID
2016-12-03 22:28:54.603 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 4. Queue={}
2016-12-03 22:28:55.744 [INFO ] [ipse.smarthome.model.script.shutters] - system startup
2016-12-03 22:28:56.229 [INFO ] [ipse.smarthome.model.script.entrance] - system startup
2016-12-03 22:28:59.589 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-12-03 22:28:59.590 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 5. Queue={}
2016-12-03 22:28:59.590 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 4
2016-12-03 22:28:59.592 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 15 E9
2016-12-03 22:28:59.593 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 15 E9
2016-12-03 22:29:04.594 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-12-03 22:29:04.595 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 5. Queue={}
2016-12-03 22:29:04.596 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 4
2016-12-03 22:29:04.597 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 15 E9
2016-12-03 22:29:04.598 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 15 E9
2016-12-03 22:29:09.600 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-12-03 22:29:09.602 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 5. Queue={}
2016-12-03 22:29:09.603 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 4
2016-12-03 22:29:09.605 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 15 E9
2016-12-03 22:29:09.606 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 15 E9
2016-12-03 22:29:14.609 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Too many retries. Discarding message: Message: class=GetVersion[0x15], type=Request[0x00], priority=High, dest=255, callback=0, payload=
2016-12-03 22:29:14.616 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 3
2016-12-03 22:29:14.618 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 20 DC
2016-12-03 22:29:14.619 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 20 DC
2016-12-03 22:29:19.621 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-12-03 22:29:19.623 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 4. Queue={}
2016-12-03 22:29:19.628 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 3
2016-12-03 22:29:19.630 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 20 DC
2016-12-03 22:29:19.631 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 20 DC
2016-12-03 22:29:24.634 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-12-03 22:29:24.641 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 4. Queue={}
2016-12-03 22:29:24.642 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 3
2016-12-03 22:29:24.645 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 20 DC
2016-12-03 22:29:24.647 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 20 DC
2016-12-03 22:29:29.649 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-12-03 22:29:29.651 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 4. Queue={}
2016-12-03 22:29:29.656 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 3
2016-12-03 22:29:29.658 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 20 DC
2016-12-03 22:29:29.660 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 20 DC
2016-12-03 22:29:34.663 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Too many retries. Discarding message: Message: class=MemoryGetId[0x20], type=Request[0x00], priority=High, dest=255, callback=0, payload=
2016-12-03 22:29:34.665 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 2
2016-12-03 22:29:34.671 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 07 FB
2016-12-03 22:29:34.673 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 07 FB
2016-12-03 22:29:39.675 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-12-03 22:29:39.682 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 3. Queue={}
2016-12-03 22:29:39.683 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 2
2016-12-03 22:29:39.686 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 07 FB
2016-12-03 22:29:39.688 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 07 FB
2016-12-03 22:29:44.689 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-12-03 22:29:44.691 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 3. Queue={}
2016-12-03 22:29:44.696 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 2
2016-12-03 22:29:44.698 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 07 FB
2016-12-03 22:29:44.701 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 07 FB
2016-12-03 22:29:49.703 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-12-03 22:29:49.710 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 3. Queue={}
2016-12-03 22:29:49.711 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 2
2016-12-03 22:29:49.713 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 07 FB
2016-12-03 22:29:49.715 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 07 FB
2016-12-03 22:29:54.717 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Too many retries. Discarding message: Message: class=SerialApiGetCapabilities[0x07], type=Request[0x00], priority=High, dest=255, callback=0, payload=
2016-12-03 22:29:54.724 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 1
2016-12-03 22:29:54.727 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 06 96 0F 65
2016-12-03 22:29:54.729 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 06 96 0F 65
2016-12-03 22:29:59.731 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-12-03 22:29:59.737 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 2. Queue={}
2016-12-03 22:29:59.739 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 1
2016-12-03 22:29:59.741 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 06 96 0F 65
2016-12-03 22:29:59.743 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 06 96 0F 65
2016-12-03 22:30:00.024 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule check time: An error occured during the script execution: The name 'dawnEnd' cannot be resolved to an item or type.
2016-12-03 22:30:04.745 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-12-03 22:30:04.752 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 2. Queue={}
2016-12-03 22:30:04.754 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 1
2016-12-03 22:30:04.756 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 06 96 0F 65
2016-12-03 22:30:04.759 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 06 96 0F 65
2016-12-03 22:30:08.821 [DEBUG] [g.zwave.internal.ZWaveConfigProvider] - ZWave product zwave:serial_zstick has no references!
2016-12-03 22:30:08.837 [DEBUG] [g.zwave.internal.ZWaveConfigProvider] - ZWave product zwave:device has no references!
2016-12-03 22:30:09.761 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-12-03 22:30:09.767 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 2. Queue={}
2016-12-03 22:30:09.768 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 1
2016-12-03 22:30:09.770 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 06 96 0F 65
2016-12-03 22:30:09.772 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 06 96 0F 65
2016-12-03 22:30:14.775 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Too many retries. Discarding message: Message: class=SerialApiSetTimeouts[0x06], type=Request[0x00], priority=High, dest=255, callback=0, payload=96 0F
2016-12-03 22:30:14.783 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2016-12-03 22:30:14.786 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 56 AA
2016-12-03 22:30:14.788 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 56 AA
2016-12-03 22:30:19.790 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 2 attempts left!
2016-12-03 22:30:19.797 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2016-12-03 22:30:19.799 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2016-12-03 22:30:19.801 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 56 AA
2016-12-03 22:30:19.804 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 56 AA
2016-12-03 22:30:24.806 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 1 attempts left!
2016-12-03 22:30:24.812 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2016-12-03 22:30:24.814 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2016-12-03 22:30:24.816 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 56 AA
2016-12-03 22:30:24.817 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 56 AA
2016-12-03 22:30:29.819 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Timeout while sending message. Requeueing - 0 attempts left!
2016-12-03 22:30:29.825 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2016-12-03 22:30:29.827 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2016-12-03 22:30:29.829 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 56 AA
2016-12-03 22:30:29.831 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 56 AA
2016-12-03 22:30:34.833 [WARN ] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Too many retries. Discarding message: Message: class=GetSucNodeId[0x56], type=Request[0x00], priority=High, dest=255, callback=0, payload=
Thanks for looking into this !
Found the problem. Not related to the new openhab build. I just found out that on RPI3, there is a conflict between bluetooth and GPIO port serial interface around UART0 which was the reason why my razberry did no longer communicate. A good source to find our more is e.g.
http://raspberrypi.stackexchange.com/questions/45570/how-do-i-make-serial-work-on-the-raspberry-pi3
Sorry for causing confusion here.
