for anyone who is interested this is how I set it up.
I am running openhab 2.4 and I had to install the latest z-wave binding (2.5.1.201912300340 │ org.openhab.binding.zwave) in order to get a Fibaro RGBW controller running (FGRGBW-442 RGBW) which is not included in the zwave 2.4 binding.
I just dropped the latest snapshot 2.5.1 into my addons folder which failed in the first since it was missing another lib - org.apache.servicemix.bundles.xstream .
In case you stumble upon the same issue. Just put version 1.4.7_1 also into the addons folder and openhab will be able to set up the updated binding on restart.
Have fun.
Philip
The install script was not working for me. Somehow the docs are not in sync with the actual script. e.g.
--ZWAVE_BRANCH
is documented but the code raised an exception since it is not a valid argument .
Also without this particular argument it did not work for me unfortunately.
Can you run it without passing arguments? The menu will guide you through it. I haven’t tried using the script with arguments in a while, so something could be messed up. I’ll take a look, but if you could, please submit an issue in GH so that I do not forget. Or better yet, fix it and submit a PR!
I’m also running Openhab 2.4 with Z-Wave 2.4.0 Binding and needed to upgrade because I bought Fibare Roller Shutter 3, which is not supported by this version.
