I installed the new LCN Binding and now my Contact show open when the door is closed.
Is this a bug ?
@fwolter
Regards
Jörg
It’s a bit hard to map from the LCN Binary Sensor to openHAB’s Open/Closed. The LCN Binary Sensor sends 0 and 1. Which of these is mapped to Open/Closed depends on the contact, wether it’s normally open or normally closed.
The binding maps 1 to Open, since this is the unsafe state for motion sensors (motion detected), from an alarm system’s perspective. The same as an open window is an unsafe state.
I would add an option to the binding to be able to invert this logic, if you open an issue. https://github.com/openhab/openhab-addons/issues
Hi Fabian,
I opened an issue https://github.com/openhab/openhab-addons/issues/8069
But in the 1.x Binding everything worked fine…
By the way, thanks for the new Binding Great work
Regards
Jörg
Most window contacts are normally closed. This might be the reason why it was inverted in the OH1 version.
