This block library is for the LCN Binding and enables the interaction with the LCN-Bus by the offered Thing actions.
Blocks
Hit Key
This block can hits a key of a key table in an LCN module.
It is useful to perform actions that the binding doesn`t support.
Dynamic Text
This block send custom texts to an LCN-GTxD display.
Note:
If your GTxD is configured in 3 row mode (button label on the upper and lower edge of the display) you can only use row 1-3.
Flicker Output
This Block let a dimmer output flash a given number of times.
Relay Timer
This block switches the selected relay on immediately and off again after the given time.
Flicker Output and Relay Timer i have only used it once to test.
Hit Key and Dynamic Text is in daily use and works perfectly.
Beep
This Block lets the beeper connected to the LCN module beep.
I only have old modules, these can only beep normal(N) and special(S) sound at 100% and max. 1-15 times.
I could not test new modules.
Changelog
Version 1.1
- Add Beep Block
- Fix display error in OH4.2
Version 1.0
- initial release
Resources
uid: LCN
tags: []
props:
parameters: []
parameterGroups: []
component: BlockLibrary
slots:
blocks:
- component: BlockType
args0:
- name: THING
type: input_value
- name: TABLE
options:
- - A
- A
- - B
- B
- - C
- C
- - D
- D
type: field_dropdown
- name: KEY
options:
- - "1"
- "1"
- - "2"
- "2"
- - "3"
- "3"
- - "4"
- "4"
- - "5"
- "5"
- - "6"
- "6"
- - "7"
- "7"
- - "8"
- "8"
- name: ACTION
options:
- - Hit
- HIT
- - Make
- MAKE
- - Break
- BREAK
colour: ffd800
helpUrl: https://www.openhab.org/addons/bindings/lcn/#hit-key
message0: Sendkey to Module %1 Table %2 Key %3 Action %4
nextStatement: ""
previousStatement: ""
tooltip: >
Hits a key of a key table in an LCN module. table - The module's key
table: A, B, C or D key - The number of the key within the key table:
1-8 action - The key's action: HIT (German: "kurz"), MAKE ("lang") or
BREAK ("los")
type: sendKey
slots:
code:
- component: BlockCodeTemplate
template: >
{{utility:things}}.getActions('lcn',
{{input:THING}}).hitKey('{{field:TABLE}}', {{field:KEY}},
'{{field:ACTION}}');
toolbox:
- component: PresetInput
shadow: true
type: oh_thing
args0:
- name: THING
type: input_value
- name: ROW
options:
- - "1"
- "1"
- - "2"
- "2"
- - "3"
- "3"
- - "4"
- "4"
- check: String
type: input_value
colour: ffd800
helpUrl: https://www.openhab.org/addons/bindings/lcn/#dynamic-text
inputsInline: false
message0: Send Dynamic Text to Module %1 Row %2 Text %3
nextStatement: ""
tooltip: |
Send dynamic text to LCN module with GTxD.
row - The number of the row in the display: 1-4
text - The text to be displayed (UTF-8)
type: sendDynamicText
slots:
code:
template: >
{{input:THING}}).sendDynamicText({{field:ROW}},
{{input:MESSAGE}});
toolbox:
shadow: true
type: oh_thing
fields:
TEXT: Text for GTxD
shadow: true
type: text
args0:
- name: THING
type: input_value
- name: Output
options:
- - "1"
- "1"
- - "2"
- "2"
- - "3"
- "3"
- - "4"
- "4"
- name: Depth
options:
- - 25%
- "0"
- - 50%
- "1"
- - 100%
- "2"
- name: Ramp
options:
- - 2sec
- "0"
- - 1sec
- "1"
- - 0.5sec
- "2"
- name: Count
options:
- - "1"
- "1"
- - "2"
- "2"
- - "3"
- "3"
- - "4"
- "4"
- - "5"
- "5"
- - "6"
- "6"
- - "7"
- "7"
- - "8"
- "8"
- - "9"
- "9"
- - "10"
- "10"
- - "11"
- "11"
- - "12"
- "12"
- - "13"
- "13"
- - "14"
- "14"
- - "15"
- "15"
colour: ffd800
helpUrl: https://www.openhab.org/addons/bindings/lcn/#flicker-output
inputsInline: false
message0: Flicker output %2 depth %3 ramp %4 count %5 to Module %1
nextStatement: ""
tooltip: >
output flicker to LCN module. output - The dimmer output number:
1-4 depth - The depth of the flickering: 0-2 (0=25% 1=50% 2=100%
Example: When the output is fully on (100%), and 0 is selected,
flashes will dim from 100% to 75% and back) ramp - The duration/ramp
of one flash: 0-2 (0=2sec 1=1sec 2=0.5sec) count - The number of
flashes: 1-15
type: outputFlicker
slots:
code:
template: >
{{input:THING}}).flickerOutput({{field:Output}},
{{field:Depth}}, {{field:Ramp}}, {{field:Count}});
toolbox:
shadow: true
type: oh_thing
args0:
- name: THING
type: input_value
- name: RelayNumber
options:
- - "1"
- "1"
- - "2"
- "2"
- - "3"
- "3"
- - "4"
- "4"
- - "5"
- "5"
- - "6"
- "6"
- - "7"
- "7"
- - "8"
- "8"
- max: 240000
min: 30
precision: 1
type: field_number
value: 30
colour: ffd800
helpUrl: https://www.openhab.org/addons/bindings/lcn/#relay-timer
inputsInline: true
message0: Switch relay %2 ON from Module %1 for %3 ms
nextStatement: ""
tooltip: >
The command switches the given relay immediately to on and after a
given time back to off. relayNumber - The relay number: 1-8 duration -
Timer duration in milliseconds: 30-240.000 ms
type: relayTimer
slots:
code:
template: >
{{input:THING}}).startRelayTimer({{field:RelayNumber}},
{{field:Duration}});
toolbox:
shadow: true
type: oh_thing
args0:
- name: THING
type: input_value
- name: Tonality
options:
- - N = push button hit (normal)
- N
- - S = special
- S
- - 1 = push button make
- "1"
- - 2 = push button break
- "2"
- - 3 = standard
- "3"
- - 4 = pecial
- "4"
- - 5 = special short
- "5"
- - 6 = error
- "6"
- - 7 = long
- "7"
- max: 100
min: 1
precision: 1
type: field_number
value: 100
- max: 50
min: 1
precision: 1
type: field_number
value: 10
colour: ffd800
helpUrl: https://www.openhab.org/addons/bindings/lcn/#beep
inputsInline: true
message0: Beep on Module %1 Volume %3, Tonality %2, Count %4
nextStatement: ""
tooltip: >
This Action realizes the LCN commmand "audio" (German: "Piepen"). It
type: Beep
slots:
code:
template: >
{{input:THING}}).beep({{field:Volume}},'{{field:Tonality}}',{{field:Count}});
toolbox:
shadow: true
type: oh_thing
utilities:
- component: UtilityJavaType
javaClass: org.openhab.core.model.script.actions.Things
