I want to control my HUE lamps with a GT12 button:
Button A1 - short = 100% brightness
Button A2 - short = 50% Brightness
Key A1 - long = 0% Brightness
Button A2 - long = 0% Brightness
Since I cannot enter the HUE parameters directly via the LCN-PRO, I only switch virtual relays via the GT12.
A1 short: Relay1=on, Relay2=off
A2 short: relay1=off, relay2=on
A1 or A2 long: relay1=off, relay2=off
The LCN Openhab connection is established. I can switch the relays via the Openhab app and via the GT12.
The HUE lamps are at output 1. The actual value of output1 is always 100%.
Via an Openhab-Rule I want to switch my lamps depending on the relay status changes.
Now to the questions:
Is this the right way? Or is there a better way?
How can I formulate the rule?
Unfortunately, this rule does not work (logwarn stands instead of the HUE lamp).
rule "Item Esstisch"
Item LCNEsstisch1 received command
switch(receivedCommand.toString.toUpperCase){
case "10000000": {
logWarn("Esstisch", "Relais 1 an")
case "01000000": {
logWarn("Esstisch", "Relais 2 an")
case "00000000": {
logWarn("Esstisch", "Relais aus")
Not familiar with Hue buttons and not aware what ‘LCN-PRO’ is - but wouldn’t you use something like the following to react on a triggered button? And have a separate rule for each triggered event?
rule "bla"
Channel "hue:0820:1:dimmer-switch:dimmer_switch_event" triggered <EVENT>
val String color = "<0-359>"
val String brightness = "50"
val String hsb_triple = color + ",100," + brightness
Hue_LR_TV_Color.sendCommand(hsb_triple)
please show your item definition for LCNEsstisch1.
On the other hand, why don’t you use a virtual output from a SH - Modul?
Then you can control this output as dimmer from your GT12 and in a rule you can catch each change and you can assoziate this virtual output with your hue brightness channel.
Torsten
With 4 keys (A1, A2, A3, A4) of a GT12 I switch 4 virtual relays.
As soon as there are changes to the relay matrix I would like to start actions. The logwarn command is just a simple example.ö
But of course this does not have to be so. There is certainly a better solution. Actually I only want to start actions depending on the 4 buttons.
@Thorsten: I have now noticed that my item configuration cannot work.
How does your suggestion look like? I can’t imagine your idea yet.
Create a rule and trigger this rule when HueEsstisch is changed.
Inside the rulebody you can cover the current state from HueEsstischLCN up to your real hue item:
